Old 08-13-2006, 09:22 AM
azswede1960 azswede1960 is offline
Brake Problem 2003 Silverado Z71
I have a 2003 Chevy Z71 Silverado, recently replaced pads all the way around. Afterwards, I am having soft pedal in the mornings when I back out/down driveway in the morning. The pedal/stopping power does build up after I pump the brake pedal and stays until the next day!!!!
No brake errors indicated on the DIC.
Air in the lines???
Old 08-13-2006, 12:05 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: Brake Problem 2003 Silverado Z71
Did you use OEM pads?
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 08-13-2006, 09:58 PM
No - you think the pads are my problem???????????
Old 08-13-2006, 10:03 PM
guumbah's Avatar
guumbah guumbah is offline
Sounds more like air in the lines. Did you bleed them? If so, try bleeding them again.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
Old 08-14-2006, 06:20 AM
That is more what I thought - will do and let you know results. Thanks!!!!!
