Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-12-2006, 09:56 PM
geofrog geofrog is offline
Send a message via MSN to geofrog Send a message via Yahoo to geofrog
Just bought 92 laser
HI, I just bought a 1992 plymouth laser, and I had a couple of questions.
The car has 133k automatic tranny, which was suppose to have been rebuilt, but is there anything I have to watch out for, that is commen with these cars?
Any advise would be great,
Oh and it has the 1.8 in it
Old 08-12-2006, 10:05 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Just bought 92 laser
With those kind of miles on it I would give it a nice little routine maintainance. New spark plugs and wires, new timing belt, change the oil and filter, change the tranny fluid, change or clean the air filter... Those things should be the only things you need to do for right now unless you see signs of other problems developing.
Oh yeah, and welcome to the world of DSM's.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Killa's Avatar
Killa Killa is offline
Throw it away j/k. Try to do all the tune up. Change all the belt and fluid, do compression, and take it easy on the car, BTW No fartcan, no wing, no body kit, it automatic man.... take it easy. BTW welcome to the forum, and put all the information about the car on your sig. BTW I like this new guy .
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-12-2006, 10:08 PM
Hello, thanks for the response. The guy I bought it from told me that the timing belt had just been replaced, when the transmission was rebuilt. but i will check everything else. If i check the timing belt, is there something i should look for to tell if is new or not?
Thanks,
KRis
Old 08-12-2006, 10:15 PM
Its really hard to tell if it has recently been replaced or 20k miles ago or maybe even longer... It is recommended that you change a timing belt at least every 60k miles. You could check for cracking or stretch marks in them. Make sure that it is nice and taunt when you try to move it. A loose timing belt could be the result of a worn timing belt or a worn out auto-tensioner. If the timing belt jumps timing you'll end up bending your valves. Its pretty much the most important thing to always check on. Check it as regularly as you would check your oil. (Hopefully its often. )
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-13-2006, 06:03 PM
Okey, I got up this morning, went out and bought a new air filter, got to the gas station, and the car wouldn't start. I just heard the relay click, but no starter or selinoid. I pulled the starter, which i must say was the easiest starter to pull i have ever worked with. took it up and it tested good. I also took the battery, which was drained down, and I replaced the turminals, As soon as I replaced the terminals it started, but the alternator was tested in the car running just over 13 volts, they said it will be okey for a while. Tomarrow I will work on the spark plugs and such.
Does anyone know where the cheapest place to buy an alternator is? and if 13 is really enought, or if i should spend the money and replace it now.
THanks
Kris
Old 08-13-2006, 06:17 PM
Autozone would be your best bet for a cheap altenator... Personally I would change it just for a safe feeling. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-13-2006, 06:19 PM
Thanks for the advise, I just was hoping I wouldn't have to spend 150 dollars for an alternator right away, but I think you are right. piece of mind.
okey,
Kris
