Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-12-2006, 05:34 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
ECU problem?
I just got the whole timing situation worked out. Now I'm playin around with the ignition timing. When the ignition timing connector is grounded (ecu grounded) the idle is good and the timing is 5 BTDC right where is supposed to be. When I remove the ground for the igniton timing connector, the timing movies to about 20 BTDC, which I'm sure ain't good and the car has a hard time idling and it basically revs itself every once in a while to get the idle back up to 1200 rpms when it drops to 800. Could this be happening just because the ECU is bad? Or might it be the IAC? Is there a way to distinguish?
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 08-12-2006, 06:38 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: ECU problem?
So does it constantly bounce between 800 and 1200 or just every once in awhile?
95 Talon TSI AWD
97 Eclipse GST
Old 08-12-2006, 07:00 PM
Re: ECU problem?
It drops back down and revs itself back up about every 5 to 7 seconds
Old 08-12-2006, 07:37 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: ECU problem?
timing should be set at 10 degrees.....
Old 08-12-2006, 07:51 PM
Re: ECU problem?
No it's 5 degrees BTDC for basic ignition timing on both the 1.8L and 2.0L, so... I have 5 here, so I'm good
But...
Actual igniton timing, when computer is ungrounded...1.8L 10 degrees BTDC, 2.0L (me) 8 degrees BTDC...unfortunately I'm at 20 not 8
Old 08-12-2006, 08:03 PM
EDMUND65's Avatar
Re: ECU problem?
mine ungrounded was at 36 lol prolly
Old 08-12-2006, 08:23 PM
Re: ECU problem?
hahaha I have a feeling that might not be the best lol, but if it runs it runs I guess, thats more than most people can say I'm sure haha
Old 08-13-2006, 02:33 PM
Re: ECU problem?
Would an OBD2 be helpful in distinguishing the problem at all? I'll check and post
Old 08-14-2006, 04:00 PM
Re: ECU problem?
Well I'm stupid of course OBD2 wont work guess I need an OBD1. I tried messin with it again today, all it did was bob between 1500 and 1200 RPMS this time with the engine re-reving about every 10 seconds this time. Still the timing is off 20 degrees btdc when ungrounded but right on 5 where it should be when grounded.
