Mystery coolant leak
99 Blazer 4.3 automatic tranny.
The water is not leaking from the front or top part of the engine. I checked the water hoses that go through the top of the firewall and they are dry. When I put water in the radiator the water is dripping out immediately down across the bell housing on the transmission. I crawled under the car but I can not find the source of the leak. Does anyone know what could be leaking back there? Thanks in advance, Tony
Re: Mystery coolant leak
Probably on top on the lower intake between the intake and the valve cover and then depending on parking angle runs down. Also there is a gasket on the rear of the intake also that can leak back by the distributer. Lower intake always goes by 100k miles.
I would agree with muddog on the lower intake, but if for some reason it's not that, then you are looking at a freeze plug...
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Thanks guys I just wish this was designed so you could actually see back there. Tony |
Re: Mystery coolant leak UPDATE
Well it was the intake that was leaking.
I removed the A/C compressor and found a BIG leak on the right side of the intake. garage wanted 500 bucks to do it so I did it myself for $45 (gasket kit) Good call and thanks again! Tony |
