Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 08-12-2006, 02:27 PM
edsel edsel is offline
nox too high failed ca. emisson test....
failed california emission test on my 86 b2000. nox reading was 1522 and the max is 1120. the reading was at 15mph. i passed at the upper speed measuring 848 with the max at 1190. what to do to get this engine to pass? test results were @15mph co 13.3, o2 1.9, hc 43, co .02, and no 1522. resulkts @25 co 1, hc36, co .02 no 848. any clues or advice greatly needed!!! thanks again edsel...
Old 08-17-2006, 01:42 PM
Cusser's Avatar
Cusser Cusser is offline
Re: nox too high failed ca. emisson test....
Check the vacuum hose going to the EGR for cracks or leaks. If none, test the EGR with a hand vacuum pump, may have to take that off and clean it to restore its operation.
Old 10-04-2006, 05:38 PM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Slap another catalatic converter on there, that should fix the problem.
Old 10-04-2006, 06:42 PM
hocbj23 hocbj23 is offline
plus a new 02 sensor.
Old 10-04-2006, 08:23 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
The EGR system lowers Nox. Your EGR valve is not opening or a passage including the valve as Cusser wrote is restricted (blocked) by carbon.
