Old 08-12-2006, 01:27 PM
1992blazer 1992blazer is offline
stereo amp draining battery
My amp is draining my battery. I have been told that my stereo amp is too big for my battery and is not letting it recharge. What alternatives do I have other than removing the amp?
Old 08-12-2006, 01:50 PM
TheBrettster TheBrettster is offline
AF Premium User
Re: stereo amp draining battery
Get a capacitor Its like a mini battery that the engine charges . Or get another battery for your amps .
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 08-12-2006, 01:59 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Really depends. It can be a mix of things draining it.
1)Check to make sure your battery is good to begin with.
2)Check your alternator to see that it is holding a charge.
3)Check all of your wires to make sure that nothing is out of whack.
Just remember that a stock battery isnt made to take the abuse abig amp will put out. Think about upgrading to an Optima with or without using a capacitator.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 08-12-2006, 02:34 PM
AF Premium User
optima or any deep cycle would be good.
Old 08-12-2006, 07:56 PM
zachzchw zachzchw is offline
Send a message via AIM to zachzchw
Might want to read some audio forums to learn the real deal with capacitors.
A very simple thing to think about....
Your electrical setup is having trouble running what you already have there....why would you add something else that needs to be powered/charged?
Youd be better off upgrading the big three, and then looking at a new battery, or high output alt.
Old 08-13-2006, 12:31 AM
BlazinMlew's Avatar
caps dont need to be charged, they just hold a charge for peaks of high wattage.
I am not starting the debate over if they are worth it or not because for some systems the are NOT worth it, but in others they are. There is alot of high end systems that run 2 or more caps. So they do serve a purpose, just not for the average guys that only push less than 300 watts or so.
I do agree though, I stated eariler that he should check and upgrade the Battery, Alt, and also look into the wires. And if nessesary go with a cap.
Old 08-13-2006, 05:45 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Bigger alternator (140 or better) Red or Yellow top battery, 1 gauge wire from alt to battery, battery to frame
Old 08-13-2006, 08:20 AM
Cloud Strife Cloud Strife is offline
Well a 1 farad capacitor can hold an extremely large charge and is the reason most use it for car stereos. Granted it may take a while to actually charge it up, the benefits of having one are very good. Your car is able to get still charge it with less strain than if you just ran off of the battery itself.
But I agreee, you need a better battery first.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 08-14-2006, 04:23 PM
y2kblazer y2kblazer is offline
As a thought... are you sure that when you shut your system down, that everything is actually turning off? ie. the amp trigger wire might not be shutting off the amp etc.
Old 08-14-2006, 09:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Is the amp drawing power when the stereo is turned off?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-14-2006, 11:22 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
I dont think it would matter. The amp draws noticable power when its getting pushed, hard. if he shuts of the car hes not using any of the amps power. The car is just keeping the amp on, Like leaving the lights on almost. that should result in a dead battery, when he starts it up. He says its draining it, assuming that is when its running and is pushing his amp. I have 2 amps in mine and i have no dimming at all. what just about everyone says on here, Get a Cap and a better battery. If ur using a HUGE amp, then you deff want to pop for a better alt.
What set up are you running?
