| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
i have to make a big decision and i hate it...
So here is the deal.
Re: i have to make a big decision and i hate it...
the sad thing is that if all these problems arent made up out of thin air and they are actually the problems with the motor. the cheapest and best route would be to rebuild/replace the motor. you can get your long block rebuilt back to stock for less than $3k and be guaranteed a quality motor or you can buy a JDM motor and take your chances but save half of your money. there are many choices...or you can just get the short block rebuilt for under $2k. good luck but it truly does sound like the best option for you would be to rip the motor out and start from scratch.
ZedEx Crew Member #4
in regards to Bernie , i have sent him alot of info, he is a very busy man, has lots of proir arrangements.
where can i get my short block rebuild for under 2k, my head is completly new , i doubt there was a problem in the rebuild of the head since it was done at a pro head shop. DAS auto is telling me 3500 for a rebuilt shortblock and labor charges ...... I really dont know what to do , if i change the short black and with this new head ....and i still have the same problem and i find out it was a faulty injector or something of that sort..... then im screwed....... then again when they take the motor apart they will know if the injectors are bad ?? right?..... |
the first thing you need to do is diagnose the problem by whoever you are having do the work. that way you have some leverage if that wasnt the problem that they fixed. anywho...check out z1motorsports.com and importpartspro.com both charge right around $3k for a full long block rebuild and id imagine that just the short block would be significantly cheaper. kyle @ importpartspro is an awesome guy and known to be the best VG builder in the country. but diagnose the problem with your car first...it could be electrical.
just a quick question cuz i dont know ...... could an electrical problem be the cause of some of the knocking in the engine???
i know that the low oil pressure is somthing else completely, but could fault coil connections be the caue of misfiring and knocking? thanks btw im gunna check those sites out , so thanks for the input |
the exact thing that the mechanic said is that i had Crankshaft journals worn and when it got warm/hot the gap would increase = low oil pressure,
now i know this is a possibility , this would be an expensive fix, what other things can i check and try to fix first??? |
well that is usually the cause of low oil pressure which is more than likely your problem. if it is for sure a knocking sound coming from the bottom end, which you will know, it is more than likely the rod bearings. but you also have other problems. beings the heads are freshly rebuilt and it seems you trust the rebuild. just get a short block ordered from IPP for $2300 and then send him yours as a core. that $2300 includes forged pistons also but i guess if you dont want the forged pistons he could build it without which could possibly save you another $500. good luck...make sure your mechanics are trustworthy. id hate to see you spend a fortune replacing something for it to be something else. as for injectors...run an OHM test. there is a test or a way to troubleshoot just about everything electrical on the car. good luck. if you can get your car to yugobernie, it would be a wise decision or maybe he can recommend you to a quality shop in your area.
ima post this here to save on bandwidth, my friend took his newly acquired 300z to a dealership n they offered him 8 grand trade in for it on a sentra spec v, he turned it down, his 300 is N/A btw in good shape has decent paint with a stillen body kit n new rims, but anyways, he turned them down, 2 weeks later he took his car to a shop n they told him he has gay compression and is only layin down 123 horses, which explains his 11.5 second 1/8th mile run... and to top it all off he bought the car for 2 grand with 94k miles and leopord skin interior!! low miles, gay interior..
I like my engine like i like my girls D's NOT B's! "I'm not a ricer, i'm a RACER!!!" John D 89 supra N/A 5 speed... SOLD, 97 Neon.. broke down <-- typical dodge 94 300... under construction |
and What and Where is IPP , Z1 doesn't have a short block rebiuld listed, 2300 with forged pistions isn't bad....... so how does the core chare work? i pay 2300 they build my shortblock, then they give me some refund after i return the old short block to them??? alot in one post but i really appreciate the help |
here's my comment
my friends a tard, and good luck with your problem man, sux when this stuff happens, specially if your broke like me.
As for your crank expanding when it gets hot and making a larger opening...... that doesnt sound right. I think either you or they got confused. When the crank gets hot its going to expand, yes, BUT it will not create a larger hole but the opposite, it will make a smaller gap to the oil passages. As for the rest of your problems all sound like the top part of your engine was just put together wrong. I dont think anything is to baddly damaged yet. You might just get away with new heads and a new set of main and crank bearings.
Last bit of advice, the Z32 300ZX is becoming a classic car in a few years and finding techs who used to work on them and know them well is going to become damn near impossible in the next few years. So I would suggest learning to work on your car yourself. It will save you alot of money and much more in headaches. And dont give the excuse, "But I dont have the time, to work on my car." you own a 10+ year old car you better find the time or sell it and get a new car with a warrenty.
Finaly got pics of my car....... after I washed it of course. ![]()
