Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 08-12-2006, 12:13 AM
LoweredCivic21 LoweredCivic21 is offline
Question Rebuilding Head
Hi guys im new to this forum so hello and nehelp wud be much appreciated.
I am the proud owner of a 00 civic Ex 2dr. I blew out the bottom end ( spun rod bearing ) and have taken the liberty to rebuild the whole damn thing. My question is..... How to rebuild the Cylinder Head? i have all Skunk2 Stage 1 racing parts for the head, but wut would be the best advice on how to do it. Do i need to port an polish it? i ordered standard compression? sized valves b/c im not turboing the motor or Juicing it. and how would i go about porting and polishing it if i do need to do that. Also how do you adjust a stage 1 adjustable Race Cam??
Ne help would do me wonders thanx
LoweredCivic
Old 08-12-2006, 09:49 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Rebuilding Head
Well, if you're doing any kind of rebuild yourself, I recomend you have at the least a Haynes manual, preferably a Helms. They will both cover everything about a head rebuild. Vtec heads are alightly more complicated than a regualr head, but with a manual, you should be fine.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-12-2006, 10:28 PM
Question Re: Rebuilding Head
I have a haynes manual, and its a lil confusing i kinda get the jist of it, but its my first rebuild so im a lil skeptical about it, but lil my dad says u never kno till u get in and do it. but will porting the head be hard and wut are the best ways about doin it to get the best results???
Old 08-13-2006, 11:09 AM
NA is Best!
Re: Rebuilding Head
A vtec head rebuild isn't really difficult, it just tedious. There are lots of small parts and specific orders for everything to go back together. If you take your time though, you can do it. As for a port and polish. The most I recomend to actually do yourself is a port match. You take your intake manifold gasket and place it over the studs on the intake side of the head. Color in any areas around the ports that the gasket does not cover and remove the metal from those areas. Do the same to the intake manifold.
Old 08-14-2006, 11:53 AM
Talking Re: Rebuilding Head
Appreciate the info there guy. ill let u know how its goes and wutnot
