Old 08-11-2006, 11:55 PM
talontsi26 talontsi26 is offline
safc2-knock
does anyone know how to use the knock feature on the safc2??
Old 08-12-2006, 02:16 AM
Igovert500's Avatar
blue + red light magnet
Re: safc2-knock
I don't know how to use it, but I do know, everyone who does have one says not to trust it. The knock detection isn't accurate enough to rely on. Basically it taps into the stock knock sensor, but isn't sophisticated enough to read the sensor like the ECU does. So it shows values which are only rough to begin with, and then you have to try and figure out a coorelation to what those values actually equate to in the ECU's 'mind'. Every 3S owner that I have heard of trying to figure this out has gotten frustrated and either given up, or got something additional to monitor knock.
Basically, it is like trying to do a mathematical proportion of 2 different fractions (knock counts/knock threshold) but you are setting the variable you are looking for equal to an estimate at best. So yeah, I'll search if you want, but in the 20 or so times I've come across this topic, I've never seen any worthwhile success. It might show knock when you have none, it might not show knock when you do.
Bottom line, if you have a 91-93 get a datalogger and forget about it.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-12-2006, 02:25 AM
Igovert500's Avatar
Re: safc2-knock
If that whole math/proportion rant didn't make sense, this is what I'm talking about:
http://www.3si.org/forum/showthread....+knock+feature
http://www.3si.org/forum/showthread....I+knock+sensor
Here it is in english, "Knock count and raw voltage from the knock sensor are two completely different things. ECU reads the voltage, filters the background noise and calculates the actual knock count. With safc-ii you can calibrate it to filter the background noise, but it's still not 'knock count'."
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-12-2006, 03:08 PM
Re: safc2-knock
where can I get a datalogger and how do I hook one up to my 93 steath rt tt?
Old 08-12-2006, 04:49 PM
Igovert500's Avatar
Re: safc2-knock
http://www.automotiveforums.com/vbul...ght=datalogger
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-12-2006, 05:36 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: safc2-knock
another one has seen the light. welcome, friend. <passes out red punch to everyone....errrrr>
sportsb4life7 just got a datalogger (though i heard he went out of town for teh weekend ). i've got a datalogger, twizted has a datalogger, now you...that makes 4. any questions or need more info, send me a PM.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
