Old 08-11-2006, 11:24 PM
Tach Holiday Tach Holiday is offline
Need Some Insight (electrical/Fuel Problem)
I have a 1991 Stealth ES. I was driving it the other day, when the engine sputtered to a stop, and wouldn't restart. It now cranks, and would occasionally stutter, but wont start. ive tested the injectors, and there was no injector pulse, and i have no spark. i have also replaced the crank angle sensor, but its the same. Is my ecu shot? or is there another sensor that could cause this? any help is very appreciated!
Old 08-11-2006, 11:44 PM
Igovert500's Avatar
blue + red light magnet
Re: Need Some Insight (electrical/Fuel Problem)
Are you getting a Check Engine light?
If yes, start by pulling the code(s):
http://www.stealth316.com/2-diagcodes91-93.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-11-2006, 11:56 PM
I tried pulling the codes, but it doesnt give me anything. not even an "ok" signal, am i doing something wrong?
Old 08-12-2006, 01:58 AM
Igovert500's Avatar
Ok, just so we are clear
A) you are getting a check engine light correct?
B) you tried pulling the codes via the method I linked to, above? (double check you are using the correct connections )
C) you have tried new batteries in your Multimeter, and are sure it isn't the problem.
If the answer to all 3 of these is yes, and you are sure you are doing it properly, then it is time to pull your ECU and look for corrosion from leaking capacitators.
ECU removal/inspection
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-14-2006, 03:49 PM
ok, i tried it again, still nothing. this time it held at about 4-5 volts, but didnt pulse at all
Old 08-14-2006, 05:04 PM
Igovert500's Avatar
Pull the ECU and check for leaking caps, it takes about 15 minutes. Directions are in the link in my last post.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-15-2006, 11:13 AM
well, i pulled it. it doesnt look -that- damaged. two of the capacitors are fine, and one is leaking slightly... can that really kill the whole thing?
Old 08-15-2006, 02:08 PM
Igovert500's Avatar
Yep.
www.avpro.com
Check out the FAQ, there is a thread on leaky caps/avpro but the basic jist is it'll cost you about $260 to get it sent there, cleaned, serviced, caps replaced, etc, and sent back to you with a lifetime warranty.
Your other option is to try and find another used ECU for under that cost, then buy new caps yourself for about $5, and pay somebody another $40 or so to replace them, before they go bad and damage the board.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-15-2006, 03:08 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
why buy another ECU? why not just send his ECU to someone (ppl on threeSi) and have the caps replaced for about 40 bucks?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-15-2006, 03:43 PM
Igovert500's Avatar
Because if one has already been leaking, the board is damaged. Simply replacing hte caps wont work now...it's too late. You need to either get the board fixed, or replace it. And as far as I know, very few people on 3si will actually fix it, and the few that do, will charge more than $40.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-15-2006, 03:53 PM
Linebckr49's Avatar
ahh, i wasn't aware that once they start leaking, the board is damaged.
but i recall a thread that mentioned all the references for repairing ECU, who would do it, and their price. i'll try to find it. but i DO know that a few would do it for around 50.
93 3000GT base
Old 08-15-2006, 03:58 PM
Linebckr49's Avatar
ya, here's the thread http://www.3si.org/forum/showthread....light=ecu+caps
one guy will replace the caps for $25, but in some cases that hasn't solved ppl's ECU problems. so it may be as you said, that once the caps start leaking, more damage is done, and simply replacin the caps won't repair all that is needed.
93 3000GT base
