Old 08-11-2006, 10:50 PM
fergys_super10 fergys_super10 is offline
Exclamation what is happening
ok my truck is a 1992 2wd 2.5l tbi with 4 in body lift. my truck broke down on the way to the store. i changed the ecm fuse and got about 20 ft from the starting point and the fuse blew again well it kept blowing so i replaced the ecm. it will start for 2 secs then the fuse blows. i have checked grounds and wires for shorts. does anyone know whats happening i need some help i think it might be the prom chip in the ecm but im a diesel mechanic so im lost with gas
Old 08-11-2006, 11:49 PM
Re: what is happening
please help me ive been racking my brain for almost a month i need some serious help
Old 08-12-2006, 05:36 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Well, a blowing fuse indicates a short. So most likely you have something that rubbed through a wire or wire bundle... Break out your chilton and start following from the ecm out...Look for visual breaks and tears and open areas and use a multimeter. Things like this are tedious and time consuming at best. I do not envy you only because I've been there. The open area is rubbing against body or frame.
Old 08-12-2006, 11:25 AM
thanks for the advice but ive checked the wires coming from the cab inside the cab and just all over for open wires showing or a short to ground
Old 08-12-2006, 11:56 AM
rlith's Avatar
Have you checked the engine harness? If so, then at this point you need to break out the multimeter
Old 08-12-2006, 11:58 AM
kok328 kok328 is offline
does the fuse blow only when it starts or can you blow the fuse just by turning the ignition key to "on" for a few minutes?
