Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-20-2002, 01:17 AM
nulldreamer nulldreamer is offline
Braking problem, why is the steering wheel shacking?
When bracking hard at higher speed, normally > 50 my steering wheel starts shacking. Is this normal? How could I fix it?
I'm driving a 94 Integra LS.
Thanks in advance
Old 08-20-2002, 03:31 PM
Marasmus Marasmus is offline
Send a message via Yahoo to Marasmus
Take your pick of possible issues. Unevenly-worn tires, out of balance radial belts in tires, warped rotors, uneven brake pressure, and even bad alignment can all cause the steering wheel to shake in hard braking.
I'd start by inspecting the tires and possibly rotating them. Rotating is good.
Have your rotors checked for warping or bad wear. If they're warped or worn down, REPLACE THEM! A minor flaw in a rotor can yield major problems in braking.
Then I'd check all your brake pads (heck, might as well replace 'em while you're there). Check to see if the outside pad is wearing a lot more than the inside pad.
If you haven't flushed the brake fluid in the last say, 2 years, you might as well do that too. It's always a good idea to do it, and it doesn't cost much to either do yourself or get done. I think most shops charge like $50 for the job.
Old 08-23-2002, 03:13 AM
thank you for your reply. It is definitely useful and I will do a little checklist.
Old 08-23-2002, 11:49 AM
AcuraBoy46 AcuraBoy46 is offline
Send a message via AIM to AcuraBoy46
I have the same problem!!!!!...but i know exactly what it is.....it's my right reat brake rotor...a small part if it sticks...it's not even with the rest of the rotor and vibrates just enough at about 55mph to make the whole car (and steering wheel) vibrate.....id say jack up the car and spin the wheels and feel for any resistance...that's how i found out my right rear was messed up...good luck
Old 08-25-2002, 03:38 PM
I will do that, thanks!
Old 09-01-2002, 12:16 AM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
it's all in the brakes man ... get pads replaced and have them check the rotars..
S2000
Old 09-02-2002, 02:51 AM
so-cali so-cali is offline
the vibrating while braking is almost always because of warped rotors. a simple machining and possibly replacing the pads should do the trick
1991 Acura Integra
Pioneer DEH-3400 Head Unit
Eclipse 82641 Speakers
4-ch 1000 watt Sony Amp
2 12" MTX 5000 subs/Bandpass Box
Old 09-02-2002, 01:45 PM
hangcool hangcool is offline
rotors
I would say they are your rotors.. do u feel a pull to either right or left when u step on the brakes ?? If you do, then the rotors are probaly bent.. get in machined.. its very dangerous driving around like that especially in the wet coz u lose control easily.
Old 09-02-2002, 08:47 PM
if it pulls its the front rotors or pads...unless the rears are severe...n e way rotors are annoying..i need new ones...:frog:
Old 09-05-2002, 02:51 PM
Hello,
Sorry for the delay, no there is no pull, but there is a wild shaking if I accelerate up to 80, no problem if I stick around 65(but that's impossible if you know what I mean and then when bracking at the above speed (80) it shakes like crazy. Yes, I will change the rotors, and the brake pads also probably next week...coz I can't go 100 safely anymore...
And here is a question, since I'm going to get 16's pretty soon, should I upgrade the rotors(larger diameter), any pros and cons on the matter?
If so, where can I get good ones at a decent price??
Thanks again,
Null
300M steering wheel shaking and pulling right?. sandrav0312 300M 1 08-07-2010 04:47 PM
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 05:58 PM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
96 Town Car: Wierd Prob w/ Steering Wheel Button(s) LieutenantCracker Town Car 6 03-05-2009 12:24 PM
Problem with the steering wheel Ennar Aveo 5 03-03-2009 09:11 AM
