95 Escort Fuel Injectors
Just a quick question.
I changed the fuel filter in june and have not gone to far of distances in the car, but I have noticed that it is very slow to pick up speed. How do I check the fuel injectors to see if they are working properly. And what type of device do I need. Thanks |
Re: 95 Escort Fuel Injectors
Sounds like it could be more of a transmission issue.
With the car in neutral, does it hesitate to jump up to high RPM? If it is a fuel injector issue it should be noticeable when you aren't driving and liekly would effect idle. If you car is a standard transmission, check that oil is not leaking from a main seal onto the clutch... that happened to me once. The car ran fine otherwise, but was slow to accelerate because the clutch got lubed :P Could just be worn out too! If an automatic there could be a few things to consider. |
Its a standard Transmission with over 320000km on it. But I believe when I had the clutch changed I think it was leaking. I'll be sure to have it replaced.
If you can find oil in the area where the transmission meets the engine, consider it very likely that there is oil on your clutch. If a leak was identified before, it should have been fixed at the time... it is a lot of work to take all of that apart again to replace a little rubber seal!
Assuming that is the problem of course... Obviously I haven't looked at your car, but I hight doubt anything is wrong with your injectors. If the engine behaves as it should and is responsive in neutral (just sit there and rev it up a bit... there should be no hesitation) then consider clutch/tranny problems. |
