Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-11-2006, 09:16 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Angry white smoke
ive been driving my car as of late, it usually sits in the garage. but i drove it for a week put like 60 miles on it or so and it ran great and boosted good when i needed it. now i drive this car like an old person cause i need it to last me a while. it has a brand new head and oem head gasket head studs you know all that jazz its built well. now i was working on some stuff like changin my transer and diff fluid and checking all my clamps today and when i started it white smoke was pouring out my exhaust and the idle was choppy like a sick set of cams now the smoke was also coming from what looked like my valve cover. does anyone have any idea what would cause this i checked all my fluids radiator is full the oil looks brand new and there isnt a single leak anywhere.
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 08-11-2006, 09:21 PM
talon-95's Avatar
talon-95 talon-95 is offline
Re: white smoke
looks like your burning oil into your cylinder (s). Could be valve stems, head gasket.
Does it go away after a while or is it constant white smoke?
Old 08-11-2006, 09:23 PM
Re: white smoke
i havent ran it for more than like 2 minutes but it stays it shouldnt be my valve stems that head is brand new and so is the head gasket. do you think maybe the head gasket i got isnt strong enough for my car now cause is just oem
Old 08-11-2006, 09:27 PM
talon-95's Avatar
Re: white smoke
Did you just replace the head gasket and it started burning white smoke after that.
If so, then you probably damaged the gasket when you were installing it or you did not torque it correctly.
Old 08-12-2006, 05:43 PM
Re: white smoke
no i drove it everyday for a week before it even started to smoke. it drove fine the day before no smoke no problems at all and then the next day i started it up and was puffing white smoke
Old 08-12-2006, 06:36 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: white smoke
How does it run?
95 Talon TSI AWD
97 Eclipse GST
Old 08-12-2006, 08:23 PM
Re: white smoke
it runs good it starts up and idles fine and it doesnt hesitate and i let it run to see if it would over heat or anything but it doesnt. i thought if my head gasket would go it would run like crap and there would be a leak somewhere and anti freeze in my oil but i dont know.
Old 08-13-2006, 03:54 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: white smoke
White smoke is not an oil problem, its a coolant problem.
Did a shop do the work? Take it back to them and tell them to fix their fuck ups. If it was you, did you torque it down properly? Its most likely a head gasket.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-13-2006, 10:45 AM
Re: white smoke
yea a shop did it they came and picked it up yesterday and said it will be ready mid week
Old 08-13-2006, 04:29 PM
Thor06's Avatar
Jizzed In My Pants
Re: white smoke
Ok. I wouldnt pay for that shit either. Its their fuck up, no way in hell should a HG go in a few weeks.
Old 08-13-2006, 04:47 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: white smoke
Although that's the norm, it's not always true. Depending on where the oil is being burnt, it can product white smoke as well.
now - 2000 civic
soon - 2002 is300
Old 08-13-2006, 05:40 PM
Re: white smoke
well they called me earlier today yes they are open 7 days a week. they said the head gasket is fine there is no fluid in the cylinders or anything like that but the valve cover has a good 6 inch crack in it and thats why there is oil all over my plug wires and the valve cover and all smoking under my hood. i thankfully have another i just got back from powder coating. they are going to stick new ngks and some taylor thundervolts in it for me and see if it still smokes if it does they are going to go into further.
they are not charging me anything other than for the plugs and wires i didnt want oil covered plugs and wires put back in it. i had a cometic head gasket a friend gave me so even if that eventually is the problem its free to
Old 09-24-2006, 12:48 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: white smoke
I have a 94 Eclipse 1.8 Sohc it has 97,000 miles on it and the valves clatter like crazy and if I let it sit all day and dont run it..it smokes like a train.
I would try driving it more or perhaps getting a fuel injection cleaning.
Old 09-29-2006, 01:22 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: white smoke
my 94 talon 1.8 will clatter every now and then to. it has 170k miles on it and used to smoke pretty good. I use the 10w30 castrol high mileage with a bottle of that stop smoke and a mobil 1 filter. I hear that fram filters are good for makin that clatter sound but i cant back it up. All i know now is that it only makes the sound for a couple minutes when first started up and doesnt smoke anymore.
Old 09-29-2006, 02:31 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: white smoke
From what I understand it is pretty easy to break the valve covers on our cars...so just tell the shop to be careful and to make sure and tighten the bolts in the correct order otherwise it will just crack again...my friend is a mechanic at the mitsu dealership here and said it happens all the time...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
