Old 08-11-2006, 07:29 PM
thermal izod thermal izod is offline
Manual Shifting an Auto...
Hey to those that race their cars...Has anyone been able to prove an advantage to Manually shifting the LT1 automatic vs. Letting the tranny do the work, as far as ET I mean...
1993 Camaro Z28: 13.75 ET @ 100.42MPH
Old 08-11-2006, 08:01 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Manual Shifting an Auto...
You will get much better results just leaving it in Drive or overdrive and this is especially true of a 94 + LT1 auto.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-11-2006, 08:12 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Agreed.
Let it shift for you. The computer knows best.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 08-14-2006, 11:22 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
i also have a questin, is it better in a 700r4 to leave it in Drive or over dirve?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 08-15-2006, 05:33 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
over drive for cruising,drive for flooring..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 08-15-2006, 12:57 PM
97cavalier's Avatar
so when i go to the track, i will put it in just drive? it only goes to 3rd in drive right?
Old 08-15-2006, 01:02 PM
Mr. Luos's Avatar
Firebird Guy
With an auto, I have heard to just put it in OD.
Just make sure you aren't WOT when it shifts into 4th gear.
Try both at the track...see if either way is better.
Stock'ish'
Old 08-15-2006, 01:08 PM
97cavalier's Avatar
why not WOT in 4th?
Old 08-15-2006, 03:29 PM
the 700R4 is set up so itll never go to 4th WOT. its just basically a 'cruise on freeway' gear to get better gas mileage, and anyway in the quarter mile you will never hit 4th gear, never need to hit 4th.. and with the throttle wide open it will never shift into 4th.. you have to be partially off the throttle, at most 2/3rds (i think it was) for the transmission to hit 4th
Car:
285's in the back
all else = STOCK.
Old 08-15-2006, 05:58 PM
jcase350 jcase350 is offline
Is there a way around that and make it shift in 4th, wide open??
1990 Iroc-z 350 TPI
Old 08-15-2006, 10:09 PM
im sure there is, because i think the only thing that keeps the 700R4 from shifting into 4th WOT is the tV cable, connected to the throttle. so if you can make it seem (to the transmission) that its NOT WOT, then it will probably shift into 4
however i heard its really bad for you to be driving fast in OD, thats why all cars only have one OD.. (less then 1:1 ratio).. just to get better fuel mileage
Car:
285's in the back
all else = STOCK.
Old 08-15-2006, 10:35 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
If I pull mine down to 1st, it'll shift at a higher RPM from 1st to 2nd than if I left it in 2nd, D or OD
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-15-2006, 11:13 PM
97cavalier's Avatar
well i got on it the other day and i think it was in 3rd doing about 85-90 and it was about to redline, so i was wondering why it did not want to shift, so all i have to do is let off a little then hit it again?
Old 08-16-2006, 01:32 AM
no, the min you get on it again it'll down shift and you'll be stuck in the same gear..you have to keep the throttle at whatever position you had it when it upshifted.
Car:
285's in the back
all else = STOCK.
Old 08-16-2006, 02:01 PM
97cavalier's Avatar
so what about the track? if i take off WOT and 3rd tops out at about 90 how will i get to 4th? will a shift kit help this?
