Old 08-11-2006, 06:07 PM
cheapertofixit cheapertofixit is offline
Help Low Oil Pressure
I just had a re-built transmission installed in my 95 PA with 104000 miles. (no indications, it just went). I got the car back today and when I stop at a light after it warms up, the oil pressure nosedives down to zero. Haven't had a chance to crawl underneath and check wiring to oil pressure sensor. The transmission mechanic noticed on test drive and informed me of the problem. my question, is there something they do when they change the transmission that would effect oil pressure? Any help would be greatly appreciated. Thanx
Old 08-12-2006, 12:05 PM
kok328 kok328 is offline
Re: Help Low Oil Pressure
Is your oil level OK?
Not sure if you'll be able to connect a trans job with low oil pressure.
Old 08-12-2006, 08:21 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
No, I can't think of any reason why a trans swap would affect the oil pressure. Check the fluid level, then check the connection to the sensor, and it that fails then your'e looking at either engine sludge build-up or the sensor went south (could have been knocked around a bit from the trans swap, but unlikely).
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-12-2006, 08:33 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
A Transmission job should have nothing to do with the oil pressure gage unless; the wiring harness going to the sending unit was damaged. I had to replace my sending unit recently, due to blockage of the orifice. The gauge was fluctuating all over the range.
Old 08-13-2006, 10:12 AM
Bassasasin Bassasasin is offline
Sounds sensor related.. My sensor quit, started reading occasionally and wrong. Its reachable and you can swap it out relatively easy. I replaced it in 30 min.
Good luck
