Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-11-2006, 03:01 PM
noyo55 noyo55 is offline
2000 Monte Carlo, hard Shifting when warm
Here is my problem. When the car gets warm the transmission goes into hard shift mode. I have hooked up a scanner--no codes even if it's running. I'm aware of the problems w/tcc valve but does this occur when there is no code thrown? Or do I have a solonoid problem which occurs when it gets warm?Or what eles would do this.I've run it up to 60 and stepped on the brake. Converter does not unlock. Any good suggestions?
Old 08-12-2006, 12:17 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2000 Monte Carlo, hard Shifting when warm
what's the mileage? have you done a trans filter change if over 50K?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-12-2006, 02:56 PM
Car has about 100000 miles on it. Has had three changes of fluid and filter, I do my fluid changes about every 30,000. At the last change it took longer(milage) before it started again.
Old 08-14-2006, 02:15 PM
richtazz's Avatar
I know this will sound strange, but other people have done it in other GM w-body forums with good success. Unhook your battery and leave it unhooked overnight. It seems to have worked for many people with hard shifting transmissions. I've never tried the trick myself, so I'm going off what others have said. I wouldn't mention it, but the people that have said it works are reliable sources, who were amazed themselves that it worked.
Old 08-14-2006, 05:26 PM
I have already done that. It seemed to work short term but it did go back to the heard shifting after driving about!
Old 09-15-2006, 03:59 PM
lb783 lb783 is offline
I had this same problem in my '99. I had to replace the pressure solenoid in the transmission.
