Old 08-11-2006, 03:23 PM
Shutterbug5k Shutterbug5k is offline
Power Steering Pump Replacement?
The power steering pump on my '99 GP GT has been whining and leaking fluid for the past few months so I think it's about time to replace it. Has anyone done this themselves? How difficult?
THANKS!!
Old 08-11-2006, 03:29 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Power Steering Pump Replacement?
Here's the general removal procedure for a GM car equipped with a Series II 3800 engine to include getting air out of the system. I'd classify it as DIY. Good luck!
Make sure engine is cold. Disconnect battery negative cable. You'll need a droplight to see what you're doing.
Remove strut tower cross brace, if installed.
Remove the coolant reservoir. If you have a Grand Prix with one mounted on the passenger side strut tower, remove it.
Remove the serpentine drive belt by loosening belt tensioner.
At this point, I highly recommend jacking up the passenger side of the car and removing the tire. Support with a jackstand. Remove the plastic splash guard. This will make getting to the pressure and return lines easier.
Remove the 2 power steering pump mounting bolts. Size = 15mm. The bolts holding the PS pump are in the 12 o’clock and 6 o’clock positions. You'll need to move the PS pulley and line up the large access hole in the PS pump pulley with the bolts. Once lined up, using a deep well socket remove them.
Remove pressure and return lines from PS pump. The pressure line is on the bottom of the pump itself and has a metal fitting. The return line is attached to the reservoir and is just a piece of tubing with a hose clamp on it. Remove pump. The pump will start leaking fluid all over the place once the lines are disconnected. Try to tie the two lines up, if possible, so that they don't fall over and start pouring out fluid.
The new pump may or may not come with a pulley and reservoir. If not you will have to transfer them from the old pump to the new one. The replacement should come with directions on how to do this but you will probably need a gear/pulley puller to get the pulley off the old pump.
Install new PS pump. Attach the pressure and return lines to the new pump. Re-mount PS pump by replacing the 2 bolts and tightening (20 ft-lbs).
Re-install plastic splash guard. Re-install tire (lug nut torque=100ft-lbs) and drop back to ground level.
Re-install the serpentine belt. This may be a good time to install a new belt.
Re-install coolant reservoir, if applicable.
Re-install strut tower cross brace.
Make sure everything is tight and properly torqued.
Re-connect battery negative cable.
Refill and air bleeding procedure (rack n pinion system):
NOTE: To relieve steering tension when engine is off, you can raise and support the vehicle with front wheels off the ground. Use good quality power steering fluid. A small funnel with a long hose attached should be used to add fluid.
With ignition off and in steering unlock position, turn wheel to the left. Now add power steering fluid to the FULL COLD mark on the dipstick. Leave the cap off. Turns wheels side to side several times without hitting the steering stops. Check fluid level again and add to maintain level at FULL COLD mark.
Start the engine and let idle for approximately 5 minutes. Turn the wheels all the way to the left and right several times without hitting the stops. Turn off engine and check the fluid level again. Make sure that it is at or near the FULL HOT line. Replace cap.
Road test car and then check for leaks. Also you can re-check fluid level again just to verify.
Timeslip 08/12/06
AF Community Guidelines
Old 08-11-2006, 04:59 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Wow, considering where it's mounted, that doesn't sound as nasty as you'd think it would be.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-11-2006, 05:09 PM
BNaylor's Avatar
Yeah, Rich deceptive isn't it. This is one of those jobs where it is easier said than done. PITA no matter how you roll the dice. I recommend having plenty of beer on hand. It will make the job easier.
Timeslip 08/12/06
Old 08-11-2006, 09:17 PM
wlkjr's Avatar
wlkjr wlkjr is offline
It's a pain getting the bolts back in. Make sure you don't knock the VSS (vehicle speed sensor) off as it sits under the pump.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 08-12-2006, 06:39 AM
richtazz's Avatar
My power steering is starting to get a little stiff every once in a while at parking speeds(hence the interest in the proceedure), so I'm keeping an eye on it. No growling or whining yet though. I hope it's not a rack and pinion issue.
Old 08-12-2006, 12:19 PM
BNaylor's Avatar
Has anyone trying running Seafoam (same as the tranny additive) into the power steering system? I heard it does wonders.
But I'm not really an additive fan unless absolutely necessary. Stuff works well on our tranny...at least helps.
Timeslip 08/12/06
Old 08-12-2006, 01:05 PM
richtazz's Avatar
I heard the Lucas power steering additive is the cat's meow. I have a cab company that buys it from us and they swear by it. These cabs are not maintained, and they don't fix anything until it falls off. The guy that does their work said it fixed a pump that was throwing fluid all over the underside of the hood from the front seal (on a 95 Trans Sport 3800). It hasn't leaked or growled since in 20k.
Old 08-12-2006, 01:40 PM
BNaylor's Avatar
I have about 8 ounces of leftover Seafoam. The can contains 16 ounces. I was wondering if the stuff really works. You don't use too much but supposedly it conditions the seals and gets rid of power steering noise.
I was going to try this out in a '00 Chevy Lumina (brother's wife).
Yeah, those cabs companies are a trip. Can't say they really have a good fleet maintenance program.
You ought to see the cabs in Mexico.....lol.
Timeslip 08/12/06
