Old 08-11-2006, 01:37 PM
Blazer SS Blazer SS is offline
The Blazer has plastic fuel Lines!!!!!!!!!!!!
Can you believe it? The 98 Chevy Blazer LT, 4x4 ,262, v6 , 4 door, fuel injected, Poppet valve equiped, Fun Machine. HAS PLASTIC FUEL LINES!!!
I couldn't believe it !! I jacked up the truck and got underneath to sort out a fuel problem, armed with a new fuel filter and assorted tools. I just knew that I would be done in 30 minutes or less. Right !!
After removing the fuel filter and checking the flow rate of the rear fuel pump, then checking the front inline fuel pump, my eyes looked past the fuel filter and at the underside of the floor pan And there they were!! 3 PLASTIC FUEL LINES!! I just started cursing, I'm running 2 fuel pumps!, and using plastic fuel lines! The truth is that they are only about 10" long But that doesn't change the fact that they are plastic!!
And since they are plastic guess what I found? the main line that leads to the injectors had a nice big kink in it. A complete 90 deg kink!! It was almost completely blocked off! I must have did this maybe a year and a half ago when I was hooking up the inline pump.
All of those Dyno runs were a waste of time and money, all of those codes that were shown by the OBD2 were all stemming from a kinked plastic fuel line!! All of that lost power that I never knew that I had. The engine is a complete beast now!! The revs fly with the slightest touch of the pedal! Can't wait to get to the Dyno now!
CHECK YOUR FUEL LINES!!! The plastic ones above the fuel filter, that could explain power issues, driveability problems, and bad gas mileage. If you have changed your fuel filter in the past , check those Plastic fuel lines! Look for kinks and twists. Check anyway, just to check ,just to check anyway!!
Did that last part make any sense??
Old 08-11-2006, 02:35 PM
Cloud Strife Cloud Strife is offline
Re: The Blazer has plastic fuel Lines!!!!!!!!!!!!
Are you gonna replace them with some other type of material ?
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 08-11-2006, 03:05 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Would you believe Dolly Parton was born that way???
How about Britney Spears?, Jenna Jamison!!!!!
Even humans are being born with plastic parts nowadays
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 08-11-2006, 03:09 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
does this mean the SS in on the road again Now i gotta keep my eyes open for ya
Old 08-11-2006, 03:21 PM
alblogg's Avatar
alblogg alblogg is offline
Could this explain why my '99 has not ran worth a crap since I changed the fuel filter about a month and a half ago? I will have to check this out thank you SS.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-11-2006, 09:00 PM
Back up again! Just for a couple of weeks. Going to do a trans rebuild. replace a few clutch packs, try out a new power servo, replace a couple of actuators . Trans stuff.
Those plastic lines are as good as gone! Gonna replace them with flex steel lines. just run your fingers over the entire length of the plastic parts and feel for bends or kinks. Man I'm glad that I looked up!!
Glad that you are up and running again. Isn't this Forum great!!
Old 08-11-2006, 10:29 PM
alblogg's Avatar
I will be looking up real close tomorrow because mine are coming out too.
Once again thanks SS.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-12-2006, 05:29 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Actually only part of it is plastic, some of it is standard fuel line...
