Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-11-2006, 10:52 AM
BLV123 BLV123 is offline
Question Replacing Head Gaskets on a 2002 3.4L V6
Is there a website I can go to, to download a set of detailed instructions with torgue specs. and so forth that will aid me in the task of replacing the head gaskets on a 2002 Monte Carlo with a 3.4L V6 engine.
Old 08-12-2006, 06:14 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Replacing Head Gaskets on a 2002 3.4L V6
Are you sure it's a head gasket and not just an intake leak? What are your symptoms?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-14-2006, 05:53 PM
Symptoms: multiple misfires, vacuum leak, oil in the water, and no power. Try to give it gas and it would slow or stall but not all the time. Sometime it would have plenty of power and in a split second it would have none.
Old 08-16-2006, 12:03 PM
richtazz's Avatar
sounds like an intake leak to me. A compression test would confirm, if it passes the compression test, you only need an intake gasket. When the intake gasket fails, it dumps coolant into the lifter valley and contaminates the oil. It also will create a vacuum leak that will cause surging, loss of power, random misfires and occasional hard starting.
