P0303 - 1996 Lumina need help
All,
I'm running out of idea's. It all started with a cam sensor code, intake manifold leak (non-internal) and a #3 misfire. I am now trying to fix the #3 misfire. So far I have replaced the wires and plugs and swapped the coils. Next I was going to check for spark and swap fuel injectors. Am I missing anything else? I thought of using a 3M injector cleaner (rec. by mechanic) but I am fearing it will kill the O2 sensor and catalytic. Please help Thanks, mazzov 1996 3.1 lumina 115k |
Re: P0303 - 1996 Lumina need help
You're on the right track. If you swap the injectors and the misfire moves with them, you found your problem (bad injector). If it stays on cylinder 3, check the injector harness with a noid light to be sure that injector is getting a signal from the ECM. You shouldn't have any issues with any cleaner harming the o2 or the cat, as long as you follow the instructions.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
O.K. I am almost on empty and there is still no change after adding fuel injection cleaner.
Can I use the test probe and poke the fuel injection wire to check for a signal or do i definitly need to swap them? When I first start the car in the morning it will give me a blinking service light. Once I start moving the light will stay on constant. If I am on the highway and I am going up a hill the light will start blinking again and then go back to being constant again. I know that a blinking light indicates a misfire and a constant light indicates an emissions problem (according to the manual). Now when I hook up the scanner it will give me the P0303 (misfire #3) code. after clearing the code it will reappear within a mile or so. Is there a chance that one of the O2 sensors went bad & how can I test it. The car use to get 27mpg 2 months ago I am now at 21mpg. Any feedback will be appreciated. Inpection is due this month
no its a misfre code. check all the conditions that would cause a misfire on cylinder 3. And no you cannot use a test light on fuel injectors, you will fry the compluter. You have to use a noid light, or i've seen LED test lights that would also probably work. You can also unplug them all and do an ohm check. If any are out of spec with the rest you found the problem. Have you ruled out anything major mechanical? Done a compression test yet?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
tblake,
Thanks for the feedback. I have not done a compression test (seems like a pain). When I changed the plugs I did notice that the #3 plug looked a little wet but not oily. I will go back to verify and try to post a pick. As far as a noid light I have never heard of them (it's been a while since I've worked on cars). How would I use the ohm meter? Where would I hook it up to? Is it easier to just remove the plenium and swap the injectors? Any feedback will be appreciated. |
yeah, its probably easier to remove the plenum and swapping them around would totally deny or confirm an issue. You would measue resistance across the terminals of the fuel injector itself and do this to all 6, if any are out of spec with the rest you may have found the issue. However this does not rule them out. Just do a compression test, keep the plugs in order, and see what the plug #3 looks like. No sence trying to narrow down a misfire if in fact the cylinder doesnt hold compression (which can cause a misfire also)
noid lights are just LED's in plastic cases that plug right onto the fuel injector harness and bling at high speeds so you can tell the fuel injector is getting current needed to operate.
ditto what tblake said in his last two posts in this thread.
Thanks guys. I will let you know the outcome.
When taking off the plenum is there anything I have to watch out for? Are the fuel injectors under any kind of pressure? Water connections?
I wound up picking up two injectors. I figured that if I'm gonna have it apart I'm just going to change it. Thanks, Vince |
Before disassembly, pull the fuel pump fuse and attempt to start the car to relieve the fuel pressure. There are two small coolant lines that go to the throttle body attached to the coolant transfer tube that runs along the front of the engine from the water pump area, over to the drivers side, under the throttle body and to the heater core.
I got some pics. How do I attach them?
Richtazz,
I took a couple of pics. If this doesn't work I will email you. Can you show me the coolant lines that you had mentioned from these pics? http://groups.msn.com/R-O-A-R-/shoebox.msnw?Page=2 Last 5 pics |
Starting near the water pump, where the coolant bleed valve is, follow that black tube that runs along the front of the engine, under the drivers side torque strut and then it turns 90 degrees under the T-Body. There are two small hoses that run from that tube assembly to the botton of the t-body. You will have to remove the air filter snorkel tube to see them.
http://groups.msn.com/R-O-A-R-/shoeb...oto&PhotoID=19 From this pic, if you remove the rubber tube attaching the air filter housing to the t-body, you'll see the two hoses that run from the black metal pipe mentioned above to the bottom of the throttle body
O.k. here is where I'm at.
I removed the fuel injector and replaced with a new one. Now I am getting a p0303 code (multiple misfire) I am thinking that this could be due to the fuel pressure (I relieved the pressure thru the end of the tube). I am also assuming that this will clear up after driving around for a little bit. After getting the fuel pressure up. Do I have to erase the code detach the battery let it sit overnight and then re-hookup the battery to properly reset the codes? Is there any other possibilities? Thanks, Vince |
