Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-11-2006, 12:34 AM
Roach88's Avatar
Roach88 Roach88 is offline
turbo project - diesel escort
my names Brandon,
i have a 87 escort lx 4 door
it has a original 2.0 diesel motor, 5 sp
and a gt body kit.
well i use to drive this thing for gas milage ( about 50 mpg) but it became a lawn orniment latly, i started to tear the car apart and turn it into a fun car.
sheet metal floors, removed the ac, and added a bar-b -que / homemade propane injection kit.
well i brought it to my high school nationals, for a kick, turn out it brought the biggest croud in, althouth it ran 23 sec 1/4
well i looking at bringing it this year ( late oct. 2006) and would like to TURBO it and surprise ppl.
i think this car has alot more in it. the diesel gives it GREAT torque but the top it is sad and it revs to albout 4500 rpms.
i came here looking for help as to wear to start in this project, and i started to read and found info on different ways to do a turbo, first my ideal was to weld a custom manifold but due to room and time im thinking about running a remotre turbo off about 3 feet of exhaust pipe from the header into the passager seat area. would this make a great boost lag? also would it be worth it to a diesel considering the boost wouldnt probaly hit till 3k rpms and ill red like at 4.5k rpms
well this is long already so ill stop here for now.
thanks in advice for any help
Brandon
Old 08-11-2006, 01:32 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: turbo project - diesel escort
Is this a UK spec car?
Because there was a turbo version of the desiel made.
I would forget about building custom stuff, when a factory turbo engine is already avlaible.
All you have to do then is source a bigger turbo, give it more boost, and provide more fuel. (I think a desiel just needs the more fuel to wind up more boost, as there is no throttle, as long as the engine can flow the air, the turbo will spin and make the boost).
Old 08-11-2006, 02:05 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
DON'T GO REMOTE TURBO. do whatever you can to keep it right after the header. specially in a diesel where cold air isn't nearly as important and can actually help performance if you can keep your egt's (exhaust gas temps) low enough.
so, I'd get a turbocharger that could get you to 15-20psi (since this is a fun car and not a daily driver you don't need to keep it reliable) and that should run ok with your high compression. you're going to need to get alot more fuel into the engine. stock it probably runs extremely lean so you could run a crap load more fuel with boost.
I'm sure someone could help you with what turbocharger to buy, I'm not really the guy to ask about that. one thing you need to do is get a pyrometer to measure egt's. this is crucial to keep your engine running. if it gets too hot, get off the gas immediately, it'll burn up your turbo and valves. another thing i'd do is run straight pipes after your turbo, you don't need mufflers or any of the emissions crap that might be on there, it'll just lag up your turbo and rob power.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 08-11-2006, 06:48 AM
KiwiBacon KiwiBacon is offline
Are you in the US? Your language and avatar suggest so. Which is a shame as that's probably the hardest place in the world to pick up a turbo for a small diesel engine.
According to Turbomaster, you'd be looking for a TB02 garret or a 1749v (variable vane) if you want a much much wider boost range.
Of course finding a suitable turbo won't be easy, most petrol engine turbos will have exhaust housings that are way too large for your engine. Maybe the propane and lots of fuel will make up for that.
http://www.turbomaster.info/eng/appl...FORD&logo=ford
For reference I have a T2 off a 2.0 diesel Nissan Serena van kicking around.
Here're the specs.
Journal Bearing T2
Compressor A/R 0.48 48mm/34mm wheel, trim 50
Turbine A/R 0.35 42mm/35mm wheel, trim 69
144111-3C600
46694311a
Old 08-11-2006, 09:44 AM
Roach88's Avatar
It is a states car. the oversea version came with a 1.8 diesel and turbo diesel.
this will be a fun car and ran only at a drag strip once.. and i dont realy care if it blows its first time out, although i would like to get at least a half a track of it pulling hard.
Im looking for the balance between the easyiest/cheapest/pure performance way to get this car into the 16's? lol (hay that would be almost cutting the et in half!) Reliability means nothin to me on this build.
I guess my main questions are do u think the 1.8 td manifold would fit on the the us 2.0 version, i also know this motor is a mazda diesel and i think mazda puts a 2.0 diesel into one of there cars.. will its manifold fit?>
and of corse what junkyard/ebay turbo should i look for max performance, remeber a quick spool on this car is probaly more important then air flow since it revs out at 4.5k rpm
also dose anyone know how to increase the fuel in these engines? cus i do understand to a diesel fuel is power!.
thanks.
Old 08-11-2006, 07:52 PM
Moppie's Avatar
Master Connector
Ah haaaa!
The UK spec car is actualy a little differnt, while its based on the same chassis, and I think uses the same look body, it actualy uses a European designed engine. Its quite differnt to the Mazda engine. So no, the UK spec turbo engine will not fit, nor will any of the parts.
However!
There is, in that generation of car, a Mazda 626 Station Wagon with a 2L Supercharged Desiel. They use a pressure wave supercharger, not totaly sure how it works, but I believe its a routes type, with the out put side exposed directly to the inlet ports on the head.
However, I know its a very unreliable enigne, made in small numbers, and it takes up a lot of space in the 626 engine bay (626=telstar=contour in the stats I think), more space than I think you have in the 323 based Escort.
However, again, I wonder if the exhaust manifold and turbo of an 1800 Familia GTR or DOHC Turbo would fit?
Might be worth doing some realy diggy to check if they line up.
Old 08-11-2006, 08:50 PM
Roach88's Avatar
well i the 626 came in a 2.0 diesel and 2.2 gas ( which is the same as the probe) i believe. i know the 2.2 wont fit,
what i did look into once was a ford tranist 2.0 turbo diesel manifold, but there impossible to find info on. they also have a new 2.4 version, those i can find. but i have no clue if it will fit. i believe there powerstroke enigines.
All this leads me back to a remote setup. it would be easier to run, when it comes to working on cars ive done pretty much from swaps to transmissions ...ect but fabbing while im ok at i dont have the tools to do it. just a cheap welder as of now. so simplisity is key! so back with the remote ideal do you guys realy think running about 3-4 ft of exhaust pipe into the passager side of the car would create a great lag? what if i use a smaller exhaust pipe and a fast spooling turbo with a big air side? i mean i can launch in the boost and power shift to keep rvs around 2.5+ just an ideal.
also i have a front mount intercooler do u think it would help or make lag worse? bov? i heard there pointless in diesel but i still love the sound.
let me know if u guys want to see pictures of anything for reference or viewing pleasure.
thanks for the help,
brandon
Old 08-11-2006, 10:28 PM
the intercooler will make lag worse, you've got to pressurize that whole area which is alot more than piping. and a bov is absolutely useless on a diesel, it'll be a waste of money and won't get you ANY performance gains.
Old 08-11-2006, 10:53 PM
Roach88's Avatar
yeah its just i already have both of them, lol kpshhhhhh <---love the sound
anyone have experience with remote mount turbos? i would like so input of the lag issues.
Old 08-12-2006, 05:34 AM
You don't want to remote mount a turbo.
For a start the exhaust will cool and contract on the way there, giving you a slower flow which won't spin the turbine well.
You'll have lost any pulse charging effect, which again will increase lag.
Then you've got the time for the engine to fill and pressurise the pipework.
Worst case is you run out of revs and have to change gear before the turbo has spooled.
Using a smaller exhaust turbine or housing to compensate won't help. It'll just provide much higher exhaust backpressure which will sap more power (exhaust brake anyone?).
Old 08-12-2006, 03:14 PM
UncleBob UncleBob is offline
AF -Advisor
lot of bad talking about remote turbo's. Yes they will be less effective than mounting it close to the exhaust ports....but it will still work. Not quite as effectively, slightly slower spool (depending on how you design it) but it will still work just fine.
It would definitely outperform the NA design, no matter how badly messed it up
Fueling might be a bigger issue though....we're not talking about an electronically controlled fueling system, are we?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 08-12-2006, 04:52 PM
Roach88's Avatar
no i believe its a manualy controled fuel system although i have no ideal how to up the fuel,
bottom line about the remote turbo i agree with u guys about there performance, although in this case i still like the ideal of the ease of install and since i only have a month to do so and work 50 hrs a week im leaning that way unless i can find a manifold made..
Old 08-12-2006, 06:47 PM
Moppie's Avatar
Master Connector
If you didn't have a time limit then i would suggest having ago at building your own manifold, then if it dosn't work mount it remotly.
But, since you do have a time limit, and as you have stated this dosn't exactly have to be a practicle car, its designed as much for spectacle as it is for function, then just go remote mount it.
Old 08-12-2006, 07:25 PM
AF -Advisor
just take off the stock manifold and weld a turbo flange to it. Done.
Nothing difficult at all....assuming you have the room, of course. Even if you don't, you can run a pipe from the manifold flange to anywhere you desire....in the engine compartment or outside of it.
Any hack with a cheesy 110V MIG welder could do this. Doesn't require any high level of fabbing. All it has to be, is high enough to allow gravity drain for the turbo, and strong enough to support its weight.
Old 08-12-2006, 09:24 PM
A supercharger would be a nice solution to this problem.
Does it have a distributor style fuel pump or an inline one? (I'm talking about how the injector lines leave the pump).
