Old 08-10-2006, 10:11 PM
laurennn laurennn is offline
i need help! with a 97 grand am se
my air conditioner wasnt blowing out cold air, it was just air from outside. i had my dad look at it; and he was going to replace the freon. well he couldnt find where to put it! does anyone know? he also must have done something while he was under the hood because now it wont blow out any air at all, not even heat!! if i could get some help i would GREATLY appreciate it! thanks!!
Old 08-11-2006, 11:09 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: i need help! with a 97 grand am se
Welcome to AF !
IF the blowrs not blowing, your father could hav knocked off the plug under the hood that goes to the blower, or the blower has died
Also your car uses(or did) use the R-12 freon which you cant get unless your a regsterd HVAC tech with the license to handle it. And is VERY expensive.
The R-12 can be removed(at a qualified shop) and adapted/switched to the new R-134a which is much cheaper and safer for the enviroment.
I'll PM you a link !
1999 Grand Am SS 3.4 OHV
Old 08-11-2006, 07:58 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Before you have someone evacuate the system, make sure its r-12, my 95 came from the factory with r-134a, and I believe it was industry standard right around that time.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 08-16-2006, 12:39 AM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
I have a 94 GA that came with R134a. The place to recharge the freon on mine is at the top back of the air compressor (furthest away from the belt).
Old 08-16-2006, 08:56 AM
yes i guess in 94-95 was when the change was made to r-134
Old 08-28-2006, 08:31 PM
mikedsera mikedsera is offline
Send a message via AIM to mikedsera
I have a 97 grand am se and you will find the the low pressure /sys fill is on the the AC compress. It is possible to charge your AC from the underside of the car while up on jack stands or ramps just becareful because the car has to be running while you charge. And you do have a 134 sys..
