Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-10-2006, 12:42 PM
landlocked landlocked is offline
Cigarette Lighter Replacement on 94 Camry
Using a laptop computer as a GPS while plugged into my cigarette lighter overheated the dash socket. I am attempting to replace the lighter socket, but I am afraid to break the trim around the radio which must be removed to access the socket.
I would appreciate more detailed advice on how to pry off the trim. Are there any hidden screws that must be removed? The repair manual was not clear.
Also I have been advised to increase the gauge of the ground from the socket since that I have been told is what carries off the heat generated from sustained use?
My laptop computer draws 90w, so any recommendations on how heavy of wire that I should use. Where I a good place to attach the secondary ground that I plan to attach to the new socket.
Thanks
Old 08-10-2006, 01:04 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Cigarette Lighter Replacement on 94 Camry
As far as the surround, there are 2 clips that hold the bottom of that surround on. They are on the bottom near the outside of each edge. I use a hook tool, like a dental pick, to get under there and pull outward. You can probably use a taped slotted screwdriver and pry outward. After the bottom is released, you pull the top in toward the dash and then down. It just catches on a little lip there. Then you disconnect the electrical connectors for the lighter and the light back there and it should come right out.
As a side note, there is a 94 Toyota factory service manual stickied at the top of this forum, available for free downloading.
Mike
Old 08-10-2006, 02:43 PM
Thank Mike,
I was able to get the surround out in one piece. Now it looks like I will have to return the generic replacement socket, since the Camry one looks pretty unique.
I now see that the existing wiring to and from the lighter socket is too light for heavy auxilary use and I'll have to decide whether to bypass it entirely and run new heavier gauge.
My son once tied directly into the battery of his car with a fused line to his boom box installed in the trunk. What do you think of that idea?
Old 08-10-2006, 02:57 PM
xfeejayx's Avatar
xfeejayx xfeejayx is offline
I think most aftermarket wiring jobs are done something like that. I have foglights that are done like that. Should work fine as long as you don't get a fuse that is too 'large', and wire is thick enough. Don't ask more from your alternator than it can put out though. 90W shouldn't be a problem at all.
Old 08-10-2006, 11:12 PM
Thanks feejay,
Yeah, that will definitely be easier. It will mean that the socket is 'always hot' but that might not be a bad thing for an auxillary circuit.
Old 08-11-2006, 07:17 AM
xfeejayx's Avatar
Thanks feejay,
put a switch on it, mount it under the dash. can't cost more than a few $. you're running your own wiring anyway.
Old 08-12-2006, 02:09 AM
freejay,
Yeah, I think that I'll go the complete aux circuit route, though maybe not on the dash.
Earlier I was removing parts (unnecessay parts) to get at the circuit and discovered that it might not be too hard to run an aux socket throught the center counsel and have the plug in the back seat.
Thanks
Old 08-17-2006, 03:23 PM
I have just finished installing an auxiliary circuit on my 94 Camry.
I used 12ga fused stranded wire from the positive terminal, routed against the firewall. The wife and I were able to pass the wire through the firewall using the factory access located by the wiper motor on the passenger side.
I installed the plug into a hole drilled in the center console on the passenger side next to the hand brake. There is enough room to mount the plug without interfering with the brake.
I routed the positive lead through the center console paying attention to secure the 'always hot' lead away from the brake mechanism. I grounded the plug using 10ga stranded wire to an existing unused bolt hole.
I was warned not to ground too close to the computer (at least 6in away and not using a common ground).
Thanks for all the help and suggestions
Old 08-17-2006, 07:30 PM
WickedNYCowboy's Avatar
WickedNYCowboy WickedNYCowboy is offline
Send a message via AIM to WickedNYCowboy Send a message via Yahoo to WickedNYCowboy
Can you guys get a 99 manual available for free downloading??
Evan
Support your local volunteer fire department
My Rides:
2003 Ford F-350 Long Horn Hauler
Others:
1999 Toyota Camry LE V6-Dad
2004 Chevy Tahoe Z71-Sister
2004 Toyota Camry LE V6-Mom
Old 08-17-2006, 10:23 PM
AF -Advisor
There should be a generation 4 manual available at Toyotanation.com at the top of the general Camry forum.
Mike
Old 08-17-2006, 11:23 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
There is a link to a '99 manual in the sticky post at the top of this forum.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
