Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-10-2006, 12:14 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
idles good until it warms up
alright now i rebuilt everything in my car. i replaced every sensor and have pretty much everything new. now when i start my car it idles at like 800 which i think is what it should be now when i drive around and the car warms up it idles at like 2500 for some screwed up reason. it doesnt surge or anything like that i used to have idle surge thats why i replaced everything it just goes up and stays there i tried adjusting everything and checked my timing i just dont know why it keeps doing that and its getting annoying
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 08-10-2006, 12:46 PM
Talon_TSI-96 Talon_TSI-96 is offline
Re: idles good until it warms up
well my 84 300zx runs like shit when its warm to and my dad thinks its the coil gets warm and seperates but that couldnt be the problem with your car.
Old 08-10-2006, 01:28 PM
Killa's Avatar
Killa Killa is offline
Did you try to adjust the TB cable ? BTW try to adjust the cable, when the car is high idle, the rpm should drop. Another reason that cause high idle is your ISC ( Idle sensor control ) or you can call it IAC ( Idle air control ), that gone bad, try take it out and test with ohm meter, let me find the link show how to test, BRB.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-10-2006, 04:09 PM
my isc and all that is brand new only got like 50 miles on it i will try the throttle cable thing and maybe check my throttle position sensor
Old 08-10-2006, 06:09 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
actually when you first start the car it should idle at around 1200 rpms it makes itself get to running temp faster. after it warms up it should be atround 750-800 whitch i dont know any eclipse that has a perfect idle.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 08-10-2006, 06:28 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
I hear ya!
Old 08-12-2006, 04:31 PM
kjewer1 kjewer1 is offline
AF - Advisor
I have posted the best procedure I've found yet for adjusting the throttle cable. Give that a shot. A high warm idle is almost always cable adjustment, the jacket expands with heat and pulls the throttle open.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
