horn and blinkers don't work - 91 LeBaron
bought the car last month for $500 as a drive around, blinkers don't work (well occasionally the right one does if I have the bright light switch pulled back and up), and the horn doesn't work at all. Hazard lights work no problem though. Any thoughts and suggestions?
Re: horn and blinkers don't work - 91 LeBaron
Check your fuses and relays. Also, you could run a hot wire to the horn from the battery just to see if the horn is actually working.
Had similar crazy stuff happen to my 92 conv. It turned out my problem was the body control module. To reset the module disconnect the battery for 5-10 minutes. This solved my problem.
