Old 08-10-2006, 10:39 AM
millerwl71 millerwl71 is offline
Evaporator Core
How do I remove the Evaporator Core? I have everything stripped down to the Evaporator Core. System is depressurized. I to the screw out by the tubes that run into the firewall. Now all I do is pull it out? Or is there something else I have to do? I have a 92 Z34. Thanks.
Old 08-10-2006, 11:59 AM
Supergumby's Avatar
Supergumby Supergumby is offline
Re: Evaporator Core
Once you get the drain pan and the heater core out, just remove the bolt from the center of the block fitting outside and the retainer clamps inside. It shoud drop right out.
Don't forget to transfer the condensate screen to the new core.
Old 08-10-2006, 12:13 PM
Re: Evaporator Core
But from the inside of my car the first thing thats there is the evaporator core. It's the aluminem one. Then behind that is the heater core which is brownish. At least I thought that was what they were. All I know is the aluminum one is first in the car under the dash.
Old 08-10-2006, 06:15 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Evaporator Core
If your talking about in the center under the radio, held in by two thin metal strips (one on top, one on bottom) with screws at the ends, that's the heater core. The evap core is much larger and more buried.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-10-2006, 09:16 PM
Supergumby's Avatar
Re: Evaporator Core
The aluminum one is actually the heater core, and the bownish one is the evaporator core.
Heater core out first, then the evaporator.
Have fun.
