Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-19-2002, 05:05 PM
rocas220 rocas220 is offline
Unhappy Power Windows Problems
1998 Mercury Grand Marquis - Electrical Problem
I cannot operate the (3) Power Windows from the passengers side.
However, from the drivers side the switches are okay.
Please let me know what I can do.
Thank you
rocas220
Old 08-20-2002, 08:40 PM
fordman123 fordman123 is offline
RE: Door lock problem
Check this first!!!
Look at your driver side power window switch
Contains all four window controls
Right below that is a lock.
This lock is to prevent children from operating the power windows
whenever the driver has the switch disabled.
You might want to try moving that switch to both positions and
check again.
That sounds like the problem
If that does not change anything, then it is related to that switch.
Haven't seen any go bad to the extent that you are describing.
Hope this is all that it is!!
Fordman123
Old 08-18-2006, 06:43 PM
Treeless Treeless is offline
Re: Power Windows Problems
Can anybody explain how to rewind the cables on powerwindow in 94 grand marquee. They came unwound
when i removed the motor.
Old 08-23-2006, 12:59 PM
2OOOLS 2OOOLS is offline
Send a message via ICQ to 2OOOLS
what do you mean by that?
Old 08-27-2006, 02:24 AM
glasser3 glasser3 is offline
Send a message via AIM to glasser3 Send a message via MSN to glasser3 Send a message via Yahoo to glasser3
how hard is it to change the window regulator in a 87
Old 08-27-2006, 04:04 AM
dont know about 87, but in 2000 there are 8 steps:
Window Regulator — Front Door, Power
Removal
1.Remove the front door trim panel.
2.Position the watershield out of the way.
-Remove the speaker.
-Remove the driver door module.
-Remove the pull strap handle.
3.Remove the front door window glass.
4.Disconnect the connector.
5.Remove the rivets.
6.Remove the Torx® screws.
7.Remove the nuts.
8.Remove the regulator.
Old 08-27-2006, 04:24 AM
thanks ill see if that works i hope it does im sick of the window not working right
