Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-10-2006, 04:23 AM
BlueGT02's Avatar
BlueGT02 BlueGT02 is offline
Wheel Hop
hi everyone, my brother just picked up a 91' 240sx LE, and there has been a lot of wheel hop with the right rear tire. Also the right rear is a lot easier to push down than the other corners. my question is would this probably weak spring cause the wheel hop?
p.s by right rear i mean passenger side
The Three Steps to Automotive Repair:
Step One: Find The Problem
Step Two: Fix The Problem
Step Three: Hide The "Extra " Parts
Old 08-10-2006, 04:30 AM
nissan_240sx nissan_240sx is offline
Re: Wheel Hop
Shocks are blown I believe?
Remove the wheel and wiggle it up and down by holding the rotor, should be stiff
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 08-10-2006, 06:26 AM
BlueGT02's Avatar
Re: Wheel Hop
does anyone know a place that I get a good set of non lowering springs/struts for the back? idealy a little sportier set
Old 08-10-2006, 08:23 AM
S13Driftfiend's Avatar
S13Driftfiend S13Driftfiend is offline
Send a message via AIM to S13Driftfiend
Re: Wheel Hop
go with oem? the only thing "a little sportier" i can think of would be some tein basic dampers or something... unless you use those cheap coilover sleeve kits which i wouldnt recomend.. your shocks will be back to the way they are now in a week. good luck
SHIFT_S i d e w a y s
Originally Posted by slideways...
you fail at life. go back into your mom's uterus and de-evolve into the nut stain i left on her sheets.
Old 08-10-2006, 12:47 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Wheel Hop
Step1: Get coilovers.
Step2: Drop your subframe and press in some solid subframe bushings.
Step3: Get full rear multi link.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 08-10-2006, 01:06 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: Wheel Hop
step 4: rob a bank
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 08-10-2006, 04:40 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Wheel Hop
just get tokico HPs or KYB GR2s. both are near OEM price and work well.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-10-2006, 06:14 PM
Re: Wheel Hop
You can do all that for under 2000$, it's not bad.
-Jonathan
Montreal, Canada
Old 08-10-2006, 08:16 PM
Chuki_breath Chuki_breath is offline
Re: Wheel Hop
this is true.......i did it lol. Well it was about 3 thousand if you add coilovers and other miscalaneous suspension stuff. But just rear multi link would be cheap and still good quality at splparts.com
I would recommend it.......its like a new car and it looks pretty lol.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 08-11-2006, 01:06 AM
Re: Wheel Hop
bings.ca has best multi link on the market. Bar none.
-Jonathan
Montreal, Canada
Old 08-11-2006, 12:58 PM
Re: Wheel Hop
^^i second that^^
