Old 08-09-2006, 07:45 PM
davidrobert2's Avatar
davidrobert2 davidrobert2 is offline
ran out of gas
I ran out of gas. I put 2 gallons in with a gas can. It started right up. I drove it up a hill to get out of the parking lot I was in and it sputtered and stalled. I rolled it back down to level ground but it won't start again. I tried for a couple of hours till my battery got weak. Any suggestions?
Old 08-09-2006, 11:54 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: ran out of gas
running out of gas is usually a bad thing. If you let your car get that low before fill up, chances are you fried the fuel pump. The pump is cooled by the gas in the tank, so its alwyas a good idea to keep the pump cool and submerged in at least a quarter tank.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-10-2006, 12:24 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
Re: ran out of gas
I had heard that before. If you let your gas get too low that you are doing damage to the fuel pump. However I usually let it go as low as I can due to high gas prices. (I have a grocery discount card).
This ain't your grandma's car!!
Old 08-10-2006, 04:29 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: ran out of gas
Yup...it should get MORE fuel as you go uphill, the pickup is at the rear, designed that way so it's more likely to run out downhill than up, for obvious reasons...so if it died uphill, just after 2 gallons (plenty), I think your pump took a puke, like blake said...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
