Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 08-09-2006, 04:04 PM
frenchy27 frenchy27 is offline
2000 Kia Sephia Problems starting
I have a 2000 Kia Sephia, I am having troubles starting it, I will turn the key and it will sputter, I will then turn the key off, wait a bit, pump some gas, turn again, and it sputters, I try this about 4-5 times and then the speed actuator assy-idle will make a buzzing sound, after the buzzing slows a bit, it starts. I have changed the spark plugs, the fuel filter, put fuel injector cleaner in it. Does anyone have any other ideas, and do you think the speed actuator assy-idle might be the problem.
Old 07-16-2007, 04:43 PM
kaeru kaeru is offline
Re: 2000 Kia Sephia Problems starting
where exactly did you find the spark plugs???? i've been looking for weeks and i can't find them anywhere.
Old 07-27-2007, 04:27 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Under the passenger front seat.
Old 07-27-2007, 04:28 PM
When it does not start try wigglling the under hood fuse box and see if it starts. Early model sephias had somee shorting issues with the fuse box.
