Old 08-09-2006, 02:54 PM
sptyler sptyler is offline
Unhappy 99 lumina jerking
I have a 99 lumina 3.1 engine v6. It starts to jerk after you have driven it for over an hour or so. It jerks when you accelerate up hills or slight inclines or sometimes on straight roads, but mostly accelerating up a hill. The jerking is intermittent you never know when it will start. If you take your foot off the accelerator pedal it stops and when you push down on the accelerator it doesn't do it as bad but can feel some slight jerking. I have driven it in overdrive and just drive and it still does it. I have had the plugs, wires, fuel filter, you name it it was done at the dealership and it still doesn't run right. I spent $798 dollars at the dealership on the above items. So I'm leary about taking it back to the dealership. Could this possibly be the TCC solenoid acting up??
Old 08-09-2006, 03:55 PM
maxwedge maxwedge is offline
A990 racer
Unhappy Re: 99 lumina jerking
Welcome to AF, what you describe could be a classic engine misfire, bad injector one possibilty, the tcc could be " chuggling from wear, or the tps could be causing it to lock and unlock, issue here is how about $800 spent and the same problem. If you brought it in for this issue, drop it in their lap and speak to SM, either they fix it or refund your money as a result of " ineffective" repairs.
Old 08-09-2006, 04:25 PM
I forgot to mention that it usually does it between the speeds of 45 to 60mph and it doesn't always do it everytime during these speeds. Plus I get no error codes or engine light on the dash.
Old 08-09-2006, 05:15 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Like Maxwedge mentioned, bad injectors will cause what you describe. At the speeds in which it's happening, it could be a TCC lockup issue(as that is the TCC lock-up threshold), but if it's that bad, the stealership should have been able to pull a code on it. Bad injectors don't trip a code of their own, but will sometimes cause a random misfire or specific cylinder misfire code if only one injector is bad. I also agree that you should talk to the stealership service manager, as I would be insanely ticked off after spending $800 and my car was not fixed.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-09-2006, 07:05 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
I had the same problem with my '99 (3.8L). It's only done it once (knock on wood) and happened when I was driving about 60-70mph. Does your car have a tach??
This ain't your grandma's car!!
Old 08-09-2006, 07:48 PM
No it does not have a tach. I went into town today and was keeping the speed under 45 and it did it once starting at 35mph. It is so intermittent never know when it is going to do it there is no commonality to it.
Old 08-09-2006, 08:44 PM
gw84's Avatar
bummer, no tach. Whenever mine did this the tach would jump around a bit. I have no clue.
Old 08-29-2006, 03:09 PM
gw84's Avatar
*Update* ('99 LTZ 3.8L) Drove the LTZ for over an hour yesterday. The shaking/jerking is back. I was driving home doing about 55mph. What should I do? Should I start cheap (plugs, wires, etc)? Also, is there anything that I should clean (egr or something)?
Old 08-29-2006, 04:01 PM
richtazz's Avatar
Yes, start with regular maintenance items such as plugs, wires, fuel filter, pcv, valve, etc... if it's been a while since you tuned her up. You can also try unhooking the battery negative cable overnight, as this has worked in the past with people suffereing from what is described as "chuggle or fishbite" (a random jerking or mis-fire like hesitation near the torque converter lock-up threshhold speed of 40-60 mph.
Old 08-29-2006, 04:06 PM
A990 racer
Lightbulb Re: 99 lumina jerking
Typical ignition misfire symptoms, based on mileage if you are due for plugs and wires do it, but stay with oe AC plats, and someone's premium wires, also Delco. There are other conditions that can cause this but basic maintenance comes first, any cel?
Old 08-29-2006, 04:25 PM
gw84's Avatar
Thanks guys, for the help! I'll take a look at the plugs tomorrow. If they're ok, I'll try the unplugging the battery cable, and see if that works. Max: what do you mean by "any cel"?
Old 08-29-2006, 06:18 PM
A990 racer
Smile Re: 99 lumina jerking
Sorry, check engine lite, typing skills are weak.
Old 08-30-2006, 07:58 PM
gw84's Avatar
I'm still new at the abrev. on here No. I haven't had a cel yet (knock on wood). Just a jerky car after driving an hour. Would you agree with Rich. about unplugging the battery cable overnight, to see if that works?
Old 08-31-2006, 12:04 PM
Blue Bowtie's Avatar
Registered Offender
Disconnecting the battery could help, but it also just as easily may not, or any "improvement" may only be temporary. The integrator function of the PCM is suually fairly tolerant of changes, and will update the block learn with any parameters that are within the acceptable programmed ranges for feedback sensor inputs. Since you are not getting any MIL (Malfunction Indicator Lamp) the inputs are likely within an acceptable range, and the PCM has probably already "learned" any changed operating parameters. Disconnecting the battery MAY clear the tables and force re-writes, but the data may end up being about the same. It can't hurt, so long as you do not have the Theft-Loc on the radio enabled and the TDM does not lose any transmitter codes. You would actually be better off by removing the PCM power fuse(s) and leaving the battery connected to back up all the other devices.
I'm guessing it's time to take a close look at the ignition and fuel delivery. Usually, ignition events are closely monitored by the PCM, and misfires are detected easily. That leaves the fuel delivery system, which is actually not monitored that closely by the PCM. Poor injector flows, poor spray patterns, high propagation times for injector pintles, and other fuel delivery problems aften go unreported by the PCM until they cause a more significant problem.
Old 08-31-2006, 07:32 PM
gw84's Avatar
Wow. That's a lot to take in Here's my abbrev. question of the evening: what is TDM? I guess I have a lot of options to weigh. Thanks all for the great advice. I'll talk to my mechanic about the situation and see what his thoughts are. I just hope he doesn't go into "...well lets start by replacing the____, then if that doesn't work will put a new ____ in..."
