Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 08-09-2006, 12:44 AM
maurobej maurobej is offline
2000 ZTS...lost key..deales charging $160.00 need option?????Is this true??
Not sure if this year model has a chip in the key...I've seem a chiped key and the one I had did not have the gray chip on top...Can someone please let me know if a 2000 ZTS needs this type of key....if so....is there a cheaper way to do it????
Thanks.....Mo
Old 08-09-2006, 10:06 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: 2000 ZTS...lost key..deales charging $160.00 need option?????Is this true??
You are screwed if you lost the key. The Dealer will have to make 2 new keys, erase the old code, and reprogram both keys. Price seems about right.
There is no other way around this.
Old 08-09-2006, 06:58 PM
Salestax Salestax is offline
Unless you have a connection somewhere at the dealership, I've lost keys in my service bays and had them cut from VIN codes.
Certified Master Tech
88 Lesabre, 93 Lesabre, 02 Lesabre
74 VW Superbeetle, 70 Maverick
Old 08-09-2006, 07:32 PM
Sure! You can cut a key with the VIN#, but Ford uses a PATS anti-theft system. Cut all the keys you want
Keys are expensive, and must be programmed with the Ford tools.
Old 08-10-2006, 08:53 PM
mr_tw's Avatar
mr_tw mr_tw is offline
tis sad but true your car will not work without the key coded at a ford dealer even if it is cut just cause it fit it will not work without being coded
What Is With The Hatred Between Imports and Domestics? In The End, We All Love Cars.
Old 08-12-2006, 03:16 AM
KimMG KimMG is offline
AF - Advisor
Check with your insurance company. Your comprehensive coverage may cover part of the bill.
