Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-08-2006, 11:52 PM
hondahappy86 hondahappy86 is offline
runnin rich problems
well lately my cat plugged up....then a big chunk of cat came out(about the size of my knuckle)...and now my truck is runnin rich with a low lopey idle....what did i mess up?
Old 08-09-2006, 09:25 PM
1thunder 1thunder is offline
Re: runnin rich problems
you didn't say the year and engine size but if it's equipped with a EGR valve then check the back pressure hose and transdeucer at the valve to see if it's burned this happens when there is too much back pressure in the exhaust and also assuming it's fuel injected disconnect the pcm for about 10-15 minutes to reset the adaptive memory
Old 08-10-2006, 09:22 AM
its a 97 with a 318.....i disconected the o2 sensors and the prob has temporaraly cleared up
Old 08-10-2006, 07:23 PM
again disconect the 3 connectors on the pcm make sure the key is off when doing this and wait about 10-15 minutes to reset adaptive memories and reconnect o2 sensor you still may have a faulty o2 sensor but this should be done first because when the cat pluggs up it senses the fuel rich the adaptive cells try to remove fuel then when exhaust flows again pcm tries to compensate and adds too much fuel as it may not be able to meet the threshold to update the adaptive fuel cells
