2002 1.8t hesitation
I have a 2002 jetta with the 1.8t and it is giving me problems. I use premium gas and synthetic oil every ~3000 miles. When it starts after sitting for over 2 hours it hesitates and jumps especially when it is in reverse. i was thinking the spark plugs or coils may need to be replacedor possibly a problem with the fuel injection. Any one have any suggestions. The car has 64000 miles and i took it to the dealer before the warranty was up and they said they did not notice any problems.
Re: 2002 1.8t hesitation
i would say the maf sensor is problably bad. ALso check the breather lines under the intake manifold as they are a VERY common problem after 55k miles. They are thin and brittle and break causing vacuum leaks. Its about 650-700.oo to have every one replaced from the crankcase to the intake pipe and to the pcv valve up the the intake manifold and brake vacuum pump.
ASE Master certified and VW certified. Just here to help all check engine light codes ------> http://www.automotiveforums.com/vbul...d.php?t=328630 |
