Unknown Part
What part is this? My truck is running missing and smelling like fuel. I looked under the hood in the dark and this part is arcing. I assume it is some kind of coil pack, but not sure. It goes straight to the distributor cap.
The arc is where the blue paint is. [img][img=http://img348.imageshack.us/img348/3164/unknownpartks6.th.jpg][/img] Last edited by baybum1; 08-09-2006 at 09:21 AM. Reason: Add Pic |
Re: Unknown Part
you have to host it on a website like www.photobucket.com or something similar
1999 GMC Sierra 1500 |
Re: Unknown Part
If I right click and select show picture I can see it.
Re: Unknown Part
98 Blazer LS 4x4 (STOCK) ---------------------------------- .ǝɹǝɥʇ noʎ ʇǝb 11ıʍ pɐoɹ ʎuɐ 'buıob ǝɹɐ noʎ ǝɹǝɥʍ ʍouʞ ʇ,uop noʎ ɟı |
Re: Unknown Part
That Part is your Ignition Coil
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
Re: Unknown Part
Re: Unknown Part
That depends on where it's arcing, If it's arcing near the wire going in it, then you need a coil wire. However, if it arc's from the coil itself, it may be cracked and will need to be replaced... Let us know how you make out with it.
Re: Unknown Part
It is arcing from the coil itself. I removed the wire and it is white and discolored. Cap[ and Rotor were changed about three months ago.
Re: Unknown Part
It is arcing from the coil itself. I removed the wire and it is white and discolored. Cap and Rotor were changed about three months ago.
Re: Unknown Part
Then replace the ignition coil, it's bad
Re: Unknown Part
Thanks, I will pick one up at lunch.
Re: Unknown Part
Please let us know if it fixes it, I have one that is burnde white and think maybe mine is bad also. My symtom is intermittent miss at light load.
Re: Unknown Part
I'll report back tonight. I just replaced the fuel filter, CPI, & Nut Kit.
Re: Unknown Part
I replaced the ignition coil which corrected the orange arc, but it was still running rough. I changed the map sensor and all plugs & wires today. Now it runs like a new truck except a vaccuum leak I haven't tracked down yet.
A/C switches to defrost at high rpm's. After shifting and back to normal rpm range A/C works fine. When on Maximum A/C 85% of air blows on dash no matter what rpm. |
