Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-08-2006, 08:45 PM
gochiefs34 gochiefs34 is offline
Throttle Problem (sensor?)
I have a 1996 Toyota Camry with 172,000 miles and a 4 cylinder engine. This morning when I started my car the RPM's skyrocketed to over 3500 and stayed there - I quickly popped it into drive and it only dropped to 2000. I popped the hood and wiggled the throttla and it seemed to run fine.
Unfortunately as soon as I started to drive my throttle just stayed open - it was like my foot was on the gas even when I was braking. My car would not lose speed unless I braked, and when ever I put it in P or N the RPM's kept climbing. Nothing seems to be wrong with my throttle structurally, and my check engine light came on for the first time, indicating maybe a sensor or something is at fault.
Please help, and thanks for any suggestions
Old 08-08-2006, 09:03 PM
hassanbigboss hassanbigboss is offline
Send a message via MSN to hassanbigboss
Re: Throttle Problem (sensor?)
Hmm, it could most definately be a sensor but I would check the Throttle Body first because sometimes the butterfly plate gets stuck in the open position because of carbon buildup. If you want to know the procedure for cleaning the Throttle Body you can search this forum and a lot of people have posted the procedure inluding me. I hope this helps but if it does not, report back and we can try to figure something out
Old 08-09-2006, 07:27 AM
xfeejayx's Avatar
xfeejayx xfeejayx is offline
Arrow Re: Throttle Problem (sensor?)
First thing you need to do is go get that code checked out. I'm fairly sure Autozone will check them for you. if not, procedure to check it yourself should be stickied at the top of this forum. Throttle plate stuck wouldn't happen all of a sudden, and I doubt it would throw a code all by itself.
Old 08-09-2006, 06:15 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
He can not check it by himself since 1996 was the first year for OBD2. He will need the proper scan tool. Autozone will check the code for him for free. Get the code read and report back here and someone will be able to offer some help.
Mike
Old 08-10-2006, 01:57 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: Throttle Problem (sensor?)
It's not the TPS sensor.
Either the throttle plate is sticking & can't close all the way, or the idle speed valve is sticking & can't close all the way.
Clean the throttle plate, ISC, and EGR valves as routine maintenance.
(Also check the throttle cable if it's been played with rescently, it may be adjusted too tight, not letting the plate close.)
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
