Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 08-08-2006, 09:37 PM
staldark staldark is offline
water blows out of radiator
when i place water in the radiatro it seems like there is compression blowing water out. there is a little water evidence on the dip stick. what could this be
Old 08-08-2006, 11:16 PM
caddydaddy caddydaddy is offline
Re: water blows out of radiator
Is this with the radiator cap off and up to temperature? If so, that's what happens.
Or does it blow water out through the coolant overflow tank? If that's the case, it could be a blown head gasket.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 08-09-2006, 06:59 AM
yes its when the cap is off
Old 08-10-2006, 06:38 PM
If this only occurs when the radiator cap is off, then that's normal. Does your car have any other cooling problems, like overheating?
When the cap is off, the coolant gets warm, and expands. Normally it goes into the resevoir, but if you have the radiator cap off, it goes out through there.
2000 Cadillac STS
Old 08-14-2006, 11:43 PM
caddyshackman caddyshackman is offline
what year is the car
Old 08-17-2006, 09:08 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
A 1987 DeVille is listed on this members profile.
These 4.1 aluminum V8 engines were known to blow head gaskets. IMO it's almost certainly a blown HG, especially with the oil contamination.
