Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 08-08-2006, 07:34 PM
tintinb tintinb is offline
Why does the lower ball joint wear so quick?
Hello,
I have 95 Sentra - which had a the Lower Ball joint (Left/Driverside Front) replaced a little over 2 years back.
I recently had a brake job done (Rotors, calipers) - and within a week there was a "screeching/squeaky" noise from the front left wheel - as if a small metal wire/sheet is moving within a closed space. I am being suggested to replace a worn out Left Lower ball joint.
Is it the lower ball joint, or something else?
Why would the lower ball joint wear away so quickly? (around 10K miles in last 2 years, and very careful driving to avoid potholes)? Also - if it is due to normal wear and tear - why the right lower ball joint would remain unaffected !!
I'll appreciate any pointers or feedback on this.
Thanks.
Tintin
Old 08-09-2006, 01:14 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Re: Why does the lower ball joint wear so quick?
Given the timing with the brake replacement I would think they forgot to lube the brake pad sliders or something to that effect. Does it happen at a particular time, like only when braking hard or when turning a certain direction? Does the sound seem speed related?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 08-13-2006, 12:29 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Agreed, sounds like the brake pad wear indicator has not been set correctly and are rubbing on your brake discs. Make sure you check that a rock has not gotten caught and is scrapping on your disc either.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 08-14-2006, 04:58 PM
slideways...'s Avatar
slideways... slideways... is offline
or it could be springs squeaking against the strut seat, or it could be the tie rods, or it could be the ball joint, or it could be a seized caliper piston with semimetallic pads...
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
