Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-08-2006, 07:04 PM
ecg2647 ecg2647 is offline
How hard is the Harmonic Balancer?
ok here goes today the rubber in the balancer came out and well needless to say here we go again its a 1994 bonnie non super charged. I can get one form yard for 75 new is 120+ tx so yard here we come. Ok so now back to im the one doing this and I not to car smart but know a few things. Im a single mom and things are tigh is it just the center nut and if I get the puller how hard will it be?
Old 08-08-2006, 07:07 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: How hard is the Harmonic Balancer?
Go to autozone.com/repairinfo for complete instructions, keep in mind you will need an impact gun to get the bolt off and a puller designed to remove GM balancers.
Old 08-10-2006, 05:30 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Why cheap out over $50 and do it again soon. The balancers are a pretty common problem on the 91-95 VIN-L 3800's, and your chances of getting a bad one from the boneyard are pretty high.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-04-2007, 05:00 PM
MERC_DoD MERC_DoD is offline
Mine was easy IF you have two people, one to hold a wide bladed screwdriver between the flywheel and housing to keep crankshaft from turning when removing or installing the main bolt that holds balancer on.
However my bonny is a 92.
