Old 08-08-2006, 04:35 PM
redwheeler's Avatar
redwheeler redwheeler is offline
fuel prices and e85
so now that fuel prices are geting even higher i was wondering what would be involved in converting my blazer to run on e 85
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
Old 08-09-2006, 07:45 AM
billibong's Avatar
billibong billibong is offline
Re: fuel prices and e85
This has been discussed on the forums before, and here is the link -
http://www.automotiveforums.com/vbul...hlight=ethanol
If you read through there you will find a link to a government website that talks about the cost of using E85 compared to regular gas. The stats indicate that it will end up costing you more money, because our vehicles don't run as efficiently on E85 - even after a full conversion - as they would on regular fuel. You could expect about a 25% DECREASE in your fuel economy.
If you are thinking about a conversion you may want to take the path of OverBaordProject and convert to diesel.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 08-09-2006, 08:31 AM
george_k george_k is offline
How bad can gas prices be there, here in montreal we are paying around $4.06 US a gallon (assuming 1 gallon = 3.7854 L)
Old 08-09-2006, 08:37 AM
G-man422's Avatar
G-man422 G-man422 is offline
Here in ohio we're at about $3.20
Old 08-09-2006, 12:16 PM
herkyhawki herkyhawki is offline
Your Blazer will run just fine on E85, so you can try a tankful to check your mileage. The problems occur with use over longer time period. Your gas tank, lines, injectors, fuel pump will all become corroded by E85. If a situation arises where E85 is the only gas available, then use it, but try to use it up soon so it doesn't sit in the tank too long.
Old 08-09-2006, 12:42 PM
biv343 biv343 is offline
I thought there were ECM/fuel mixture differences with E85 that required the ECM to be able to be able to detect/compensate for E85 fuel. I may just be misinformed on the topic.
Old 08-09-2006, 12:46 PM
G-man422's Avatar
So then any car can run on E85? i think you're mistaken. Why would GM brag about how they're the onlyones w/ the E85 cars, (then again ford has the "flex Fuel"). i just am trying to get the facts straight.
Old 08-09-2006, 01:04 PM
The Ford flex-fuel vehicles are approved for use on E85.
All gasoline engines will run on E85. If the car manufacturer does not run it on E85 in their EPA emissions testing, then they can't tell you it can run on E85. If they don't do EPA testing with E85 they also don't bother to make the fuel system components corrosion resistant.
Old 08-09-2006, 01:09 PM
G-man422's Avatar
oh, i see. thanks for the info.
Old 08-09-2006, 02:37 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
i wouldn't use it. i did research on this last semester for a paper. i checked out fuel economy.gov and according to their tests, flex fuel vehicles were ran with e85 and fuel economy suffered significatly. e85 costs less than gasoline but it takes more of it to go the same distance as a small amount of gas. basically i think its a waste. now manufacters say that vehicles will get better fuel economy and have better performance on e85 so idk.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 08-09-2006, 02:41 PM
billibong's Avatar
The link you are talking about is
http://www.fueleconomy.gov/feg/byfueltype.htm
and that is from your previous post ZL1...
and according to that site, E85 is much less economical than regular fuel. The only benefits from it are that it allows us to start breaking our dependence on fossil fuels and gives our farmers another revenue source. I guess that there is also a reduction in emissions, but that is nominal from what I've read.
billibong
Repairs:
G-man422's Avatar
^ i think its good that we will eventually not need to use as much oil though.
Old 08-09-2006, 02:44 PM
billibong's Avatar
There are definite benefits to not using as much oil. I think that the US has to put more emphasis on other alternative fuels and making the hybrids more economical and efficient. I look to the concept of the hydrogen fuel vehicles as being a real benefit and something we should continue to pursue.
billibong
Repairs:
Old 08-09-2006, 03:53 PM
Cloud Strife Cloud Strife is offline
So what happens if you mix/match your fuels ?
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 08-09-2006, 08:24 PM
redwheeler's Avatar
see i thought this would spark a big opionated debate and almost did not start this but i really thought about this and researched it and i thought some one here would know so i posted
