Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-19-2002, 08:04 AM
QueenMaXimA's Avatar
QueenMaXimA QueenMaXimA is offline
Send a message via AIM to QueenMaXimA
Replacing The Starter
Hey guys i need help real fast... I need a place where i can find good directions on how to replace the starter in my 96 SE Max. OR if you can give me good info on how to replace the starter, then please email me or just write it here. Thanks for your help!!
In my race agaist time I...Keep runnin through the red light...
Old 08-19-2002, 10:32 AM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
Easy. Unplug the battery first. for the starter tHeir are only two bolts holding it in, one is 17mm, I THINK the other is 14mm, but I could be wrong. Anyway, first unplug the wire going to it, this is your ground, then unscrew the other wire, this is the power, don't loose the nut and washer. Once the two bolts and wire are removed, just pull the starter out. Put a new one in, put the bolts back in, tighten them down, put the wires back together, connect your battery, and start it up!
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Old 08-19-2002, 12:39 PM
twistedmaxima twistedmaxima is offline
Send a message via AIM to twistedmaxima Send a message via Yahoo to twistedmaxima
Thumbs up PRETTY GOOD
I WAS ABOUT TO SAY THE SAME DAM THANG.:jump:
Old 08-20-2002, 12:11 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
haynes manual has pics
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 10-24-2002, 10:47 PM
maximafever maximafever is offline
One thing that will make it easier to get to is to remove the air intake system. it sounds like a lot of work, but the starter is real hard to get to an dif it is the first time that you are replacing it yourself then its probably going to be torqued pretty tight. The job should take about an hour or less depending on how mechanically inclined you are.
Old 05-23-2005, 09:26 AM
msisti msisti is offline
testimony
I knew something was wrong when there was a whinning/grinding sound for about 1 second after the engine started and I released the key. Everyone I asked suggested it was the starter going bad.
Replacing it really was quite simple. I removed the air intake and then the starter, bolted the new one in and but the air intake back on. The hardest part was loosening the larger bolt that holds the starter on. I slid a long length of pipe onto the wrench for leverage. For a job the dealer wanted $450 for, I was able to do it with a $150 part and replaced it in about 1hr 30 min.
