Old 08-08-2006, 03:12 PM
kaho's Avatar
kaho kaho is offline
Mitsubishi Lancer Evolution 8 MR
Kit by Fujimi.
First modification I have done were the door panels. Only the front ones are done as of now. All windows are cut out individually and will be glued on separately to remove gaps between body and glass.
Rear bumper were slightly too wide to fit the main body so I heated it with boiling water and then bend it back inwards. Now it fits flush with the body.
Center console combined both new and old interior tub piece to be more accurate.
I drive a same year Lancer in real life with exact interior so I could put a little more correct details into the car =)
Old 08-09-2006, 09:14 AM
integradical's Avatar
integradical integradical is offline
Re: Mitsubishi Lancer Evolution 8 MR
nice job what your doing on that lancer
INTEGRADICAL MOTORSPORTS
current projects:celica t23,civic si coupe back under construction,opel astra and vw golf(clean wide and low)
Old 08-09-2006, 09:15 AM
G-man422's Avatar
G-man422 G-man422 is offline
lookin good so far.
Old 08-10-2006, 05:56 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
nice! hope to see more progress pics.
i hate the fact that fujimi's evo cockpit tubs are soooooo lacking in detail
and yet i keep buying em. LOL!
olly olly oxen free
Old 08-13-2006, 09:12 PM
kaho's Avatar
Here are a closer view of the inside door panel:
Next step: modifying Fujimi crappy suspension to have a correct stock stance. Excuse the dark pictures.
Front suspension unchanged. Rear suspension lowered 1mm and track width narrowed 2mm. Otherwise the rear wheels would stick out of their fenders.
Old 08-13-2006, 10:01 PM
bigfrit's Avatar
bigfrit bigfrit is offline
Astonishing work you already did to it!
I just love the way the windows sit flush with the enclosures, that sure must have taken a lot of work to get this right. And those little details on the interior look just like they came out of the box, that's the best compliment one could have!
A little tip, when you re going to put the windows in, try 'painting' the outer edges, where you cut the windows, with some kind of black permanent marker, that way the clear plastic will look less like plastic.
Awesome job sofar, I m digging it!
Oli
Old 08-14-2006, 04:25 AM
Guiddy's Avatar
Guiddy Guiddy is offline
Nice car and if Fujimi is the only company to make it then glad you are trying to improve it.
You will get dark pictures if you take them against a window!
Turn around and take the photo with the window behind you or use the flash!
Old 08-14-2006, 10:22 PM
KevHw's Avatar
KevHw KevHw is offline
I really like what you've done to the windows, makes it look much more realistic. Door panels look great too. Keeping my eye on this.
Old 08-14-2006, 11:14 PM
bhop73's Avatar
bhop73 bhop73 is offline
I had the same "issue" with my Eclipse model. The reason I call it an issue and not an advantage is because, since you look at your car everyday, it's hard to know when to stop and if it's not perfect, it might drive you crazy.. hah
It's really looking great so far. Keep it up!
http://www.bhop73.com/
Old 08-15-2006, 01:11 AM
kaho's Avatar
bigfrit: Thanks I will remember to black out the edges. These windows will need some touch up with sandpaper/compound and future wax too.
Guiddy: I tried taking the pictures with flash on but it seems to become too bright. I will try moving the product somewhere else to take pictures. Right now there are only teasers =)
bhop73: , I can just imagine how big of a project this will become if I try to replicate everything in the real car.
Also I built some mounting points for the body and chassis so that the front bumper is not needed to hold them together. The fitment of body and chassis using the bumper alone is too flexible and unbalanced. Notice the white plastic pieces.
Old 08-15-2006, 01:22 AM
digitalbanzai's Avatar
digitalbanzai digitalbanzai is offline
Looks like another kit to add to my list!
Old 08-16-2006, 04:23 AM
nice idea with modifying the fitment points!
olly olly oxen free
Old 12-21-2006, 02:38 AM
kaho's Avatar
Finals are done! I have about 10 days to finish up this model -.-''
Opened up the front bumper slits, remade door handles, vortex generator, antenna, rear brake light and speakers.
Old 12-21-2006, 03:25 AM
quadzero's Avatar
quadzero quadzero is offline
It's putting in the extra time like this that really makes a model shine. This process must have taken a lot of time to do, great job you did with it.
Bigfrit, thats a good tip. I'm going to have to remember that one.
Old 12-21-2006, 05:34 AM
bai's Avatar
bai bai is offline
wow ur version of inner door panel is much better than mine
Let me re-intorduce myself
