Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 08-08-2006, 01:28 PM
larrycurtis larrycurtis is offline
Question 2003 Passat auto trans indicator lights
2003 1.8T Passat with auto trans. Dash lights indicating transmission selection do not change no matter gear or mode (auto or tiptronic). All I get on the dash is black PRND432 against a red background all the time. Transmission works fine and when placed into "manual" or tiptronic mode I can change gears - I just have no idea of what gear I'm in. Fuses appear OK but I haven't pulled any to look at closely.
Old 08-16-2006, 11:55 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 2003 Passat auto trans indicator lights
2003 should be under warranty
Old 08-17-2006, 02:20 PM
If only............. It has about 53,000 miles (and only one oil pump replacement) and therefore has gone beyond its warranty coverage. Do you know of anything short of a visit to the dealer I could do? I can see no loose wires and fuses are all good. Can't remove the cover plate around the lever for fear of breaking something.
Old 08-18-2006, 01:41 PM
guumbah's Avatar
guumbah guumbah is offline
Isn't the display of that part of the trip computer display? Anything else wrong with the trip computer? Miles incorrect, mileage, etc.
Old 08-19-2006, 10:44 AM
Thanks for your response. All of the trip computer functions work fine. Miles are correct, the outside temp. works fine and I've run the trip computer through all cycles/displays and there are no problems. It's just the indicator section for the autotrans. It's really got me stumped.
Old 08-22-2006, 07:34 PM
localvw localvw is offline
means u have fault codes in the transmission control module
Old 08-24-2006, 03:29 PM
VDUBMAN
Originally Posted by larrycurtis
If only............. It has about 53,000 miles (and only one oil pump replacement) and therefore has gone beyond its warranty coverage. .
powertrain warranty= 5yr 60k miles
transmission is a powertrain component, any qualified vw warranty personnel should know that!
