Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-08-2006, 12:56 PM
vasta41 vasta41 is offline
upper control arm 95 Bird
I recently had both right and left upper control arms replaced because of a bad ball joint on the left side,(you could hear it knocking when you hit a bump). After the repair every thing was fine for a couple of months,now that same noise is back on the left side. The previous owner had the car lowered with a new set of springs all around and the tire size is 275/45/17 on all four corners. Is there a different control arm I should get because the car has been lowered or do you think the 275's are too big for the stock front end components? Strange that it happened on the same side. Thanks for your time guys
Old 08-08-2006, 03:41 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: upper control arm 95 Bird
Inspect the front end first. A bad sway-bar link can also make a similar noise.
Old 08-08-2006, 06:34 PM
overl0rd overl0rd is offline
Strut rod bushings can make that noise too. Just curious, the tires aren't hitting the fenders when you hit bumps right?
Old 08-09-2006, 12:20 AM
Course not, they fit fine... just a little bigger. I'm thinking the easiest solution would be to just raise the car back to stock at this point...
Old 08-09-2006, 02:00 PM
intrcptrbird intrcptrbird is offline
Send a message via AIM to intrcptrbird
Well first, Mine is lowered 2". it uses the same control arms and such. 2nd I was I was told that a 245 was the widest tire you can fit on the front of these cars. Third, almost ANY bushings on the fornt end could cause a noise on a bump. I had a poping noise almost evertime I turned or hit a bump (started off only when i hit the bump and very intermitent). It turned out to be 2 loose bolts on the large cross member that the rack and pinion and lower control arm are mounted on. I would take it to a GOOD and trustworthy tire and suspension place and have THEM check the tire clearances, all the bushings, and asocciated nuts and bolts. I put money on it NOT being the upper control arm/ball joint unless the drop was done TERRIBLY wrong.
Old 08-09-2006, 09:31 PM
I was under the same understanding.
