big problem
ok i hvae 2005 ls sedan dealer has tried to fix my car three time now for a noise comming from drivers side sounds like a rattle inside car in dash when i drive slow over bumbs almost like the suspension is bad any ways the first did a interm shaft, then a sterring gear kit, and then strut mount still doing it all that and it still the same lol any mech have any ideas
Re: big problem
its a Gm econobox, what do you expect?
Re: big problem
Re: big problem
^ I'm sorry, thats too much to ask. lol, j/k, can the noise be heard from outside the car?
Re: big problem
Re: big problem
You have to start using words at the dealer like "lemon law". The deal is that id they can't fix a problem after repeated tries, they should take the car back or make you a deal on another one. But definitely ask how to contact the local GM representative, that usually gets them motivated to fix it right.
Bob |
Re: big problem
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle. |
Re: big problem
How about an update? Did the dealer get it fixed? At least you have a dealer that is trying, that's 3/4 the battle with GM these days.
Yeah my 2006 2 door colbalt LT has the same problem. The dealer replaced the steering shaft and it is still doing the same thing when I go over bumps
Re: big problem
Has anyone tried removing all of the plastic "garbage" covering in engine? I have been having the same noise and am going to see if this cures the problem. Will keep all posted as to what the outcome is.
Re: big problem
Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Re: big problem
Was referring to not just the engine cover but also the fuse / relay box and the cover just forward to that also. My noise seems to be coming from under the hood in that general area. Sounds may be radiating and sounding like it's coming from behind the instrument cluster. And sorry about bringing up old history but am new to the forum. Hope one of us can figure out this annoying rattle we are having.
