Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 08-07-2006, 09:13 PM
thebrie thebrie is offline
engine oil light & clicking, but no start
my check engine oil light came on, i checked the oil and it's fine. but my car won't start and just clicks, and then engine oil light flickers? did i destroy my car???
i have a 2001 ford focus
Old 08-07-2006, 09:36 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: engine oil light & clicking, but no start
First of all, try to manually turn the engine over to see if it is siezed or not. It may be a bad starter and an oil sender.
If it will not manually turn over, then it's toast.
Old 08-08-2006, 03:47 AM
BMW320i's Avatar
BMW320i BMW320i is offline
Send a message via MSN to BMW320i
The oil light is on or flickers since it is not running. Nothing to worry about. You prob have a bad starter or battery. You can have them checked for free at parts stores. Or the battery checked at Les Scwabs. One way to see if the battery is low is turn on everything headlights high beams hazards radio etc. Now turn on the wipers on fast mode. If they are fast your battery is not dead. IF they are slow the battery is definatly too low to start the car. So if the battery is good now check the battery connections. Are they corroded. Can you turn or take off the connections. Make sure they are tight. If it is a stick try push starting it. If it turns over or runs then your car is not toast. You just need a starter prob.
1998 Lincoln Navigator
1988 BMW 320i (german) 1997 Lincoln Mark VIII
2004 Suzuki GS500F 1984 Honda V45 Sabre
1990 VW Golf II (german) 1994 Lincoln TC
Mechanic on the Army STRYKER
