Car running rough
Damn my car is running like hell.
Its missing badly specially at lower rpm, hesitates when accelerating and there is a noticeable different in power obviously. There are two things I’m thinking that could cause this, maybe the ignition leads or it’s the Mass air sensor. the car is also searching at idle. I say ignition leads because I saw one of them sparking at nigh time when I had a check under the hood. What do you guys think???? |
Re: Car running rough
Think you should pull the codes.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
and check your spark plugs, make sure there gaped right. bad plugs equal hesitation
Yea thanks it was due to the Ignition lead, problem now fixe for a mere $180.00 NZ
I guess you may call them spark plug leads, I didn't have to change the spark plugs
![]() Upgrades... To many to list...
if u pop ur hood and look at ur engine, u will see 6 large black wires connected on the left side next to the plate that says mistubishi on top and ur engine type on the bottom (ie V6 DOHC 24V) in large white lettering. each wire connects to a spark plug in each cylinder and provides the electricity for the spark that ignites the gas in each cylinder. if one spark plug isn't firing correctly because of a bad wire, it would cause ur engine to run badly and have a terrible idle. by looking at the entirety of each wire u should be able to see if any are worn or broken and if they need to be replaced. i tried to send a picture for clarity but it wont go through for some reason. unfortunetly im not a car know it all so i can't tell u much more than that. anyone with more knowledge want to shed some more light?
Wow i should really read all the of thread before posting. those are what ur spark plug wires are but if u replaced the spark plugs and wires then thats not the problem. the starter lead is the wire that goes to and from the starter in ur car but a bad starter lead wouldnt cause a bad idle and slow acceleration. u sure u replaced the spark plugs AND wires? cause if its not electrical ur probably getting into big bucks for repairs.
Problem already fixed, it was one of my spark plug wire's or maybe even the spark plugs since I replaced both, I saw one of the leads sparking at night which lead me to the problem......
No the other thing that could cause this sort of problem would be the Mass..... |
i figured 92VR4red might have the same problem but not if he replaced the plugs and wires. wait so then if leads aren't the wires what are they?
lol bro your confusing me.
Look, I replaced the blue leads in the pic below......
or it could be the The Mass Air Flow Sensor which converts the amount of air drawn into the engine and can cause thing like poor Idle and the obviouse performance!!!
Don't take my advise though, if things are looking bad get your car put on Mitsubishi's Diagnostic computer. |
where how do u do that? do dealers have them? cause i've been wondering about my oxygen sensor for a while. whenever i push in the clutch and i haven't let off the gas for at least a full second the rpms jump. also my engine is idling lower and lower when its cold, sometimes stalling and making me start it up again and hold the gas down for a couple seconds. lol idk how much worse it'll get before it gets better. then again if these things have nothing in common and neither of which have to do with the oxygen sensor it wouldnt surprize me in the least cause i hardly know anything beyond basics about cars.
