Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-07-2006, 09:37 PM
96P71 96P71 is offline
Talking 1996 Crown Vic, Police Interceptor- Headlight Problem
My 96 Crown Vic PI has served me well unitl recently . When I have the headlights on, occasionally they will turn on and off very repidly. If I turn the Headlight switch off and turn it back on it seems to cure it for a few weeks. It doesn't seem to happen during a specific time, temperature, etc. It also happens when the headlight switch is set to auto on.
Another issue, possibly related, is that when I use the "flash to pass" I hear a slight buzzing noise. This also affects the wipers if they are on.
I really appreciate the help everyone here seems to offer!!!!!!!!!!!!!!!!!!! THANKS!!!!!!!!!!!!!!!1
Old 08-07-2006, 10:26 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: 1996 Crown Vic, Police Interceptor- Headlight Problem
The headlight switch may have a loose connection or is getting bad from heat/age. I would check that first.
Old 08-08-2006, 09:30 PM
Checked the connector, no signs of melting, burning, or otherwise discoloration. It seems to sit pretty snuggly in the switch too. I took it apart and cleaned the pins just to be sure. Unfortunately the lights turned on and off before.
Old 08-08-2006, 11:34 PM
fleettech fleettech is offline
probably the multi function (signal light,wiper.dimmer) switch very common problem easy to change but costly to just throw at it without knowing for sure.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 08-09-2006, 08:08 AM
krewl1 krewl1 is offline
Not sure if your model has it but on our 98 vic it turned out to be our LCM (lighting control module).
Old 11-10-2006, 11:34 PM
raziullah007 raziullah007 is offline
Just a fruitful thought! Can't hurt to bother with this!
Have you recently put in new lightbulbs?? If you have, and if you have bought the HID and other "bright" performance lamps (bulbs), this could be it. I personally put higher wattage so-called "performance" bulbs in my 99 P71 police interceptor cruiser (NOT A CROWN VIC!!!!!!! )----i hate when peopel call it crown vic...anyway) and it started to blink out on me. Check that out just to be sure.
Old 03-04-2007, 02:01 AM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
FLEETTECH - Is there a fix for this? I have a new set of headlight assemblies ready to install, am I going to have this same problem?
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
