| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
car has been running pretty much fine until tonight. I've had a belt squeal since i had bought the car over a year ago and the check engine light has been on for a few months now but i got home from work today and turned off my car then went to leave a few hours later and my car turned right over and i heard a weird noise almost like a high pitched vacuum sound then something clicked and my car turned off then would not start after that. at first it was turning over just fine w.o starting but now every time i try to turn it over it gets weaker and weaker and sounds worse and worse. it now almost sounds like 2 metal plates rubbing together when i try to start it. please any info or suggestions would help thanks a lot.
Re: problem starting 97' gst
SEARCH! POST IN CORRECT FORUM!
![]() maybe starter/bad battery/timing belt gone and how many miles are on the car? |
about 108k its a fairly new battery also, less than a year old
most likely start if it sounds like grinding, make sure your battery is fully charged
